Build a PC with $700!
Go to solution Solved by SkywardKkalox,
I would build something like that instead:
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor ($183.88 @ OutletPC)
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard ($89.99 @ Micro Center)
Memory: G.Skill Ripjaws 4 series 8GB (2 x 4GB) DDR4-2400 Memory ($43.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: XFX Radeon R9 380X 4GB DD XXX OC Video Card ($223.98 @ Newegg)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case ($59.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($54.99 @ Newegg)
Total: $706.80
Generated by PCPartPicker 2016-01-12 12:44 EST-0500
Only thing that I'd change is that NEX PSU. And the mobo to an h170 if he doesn't get a K series CPU in the future.
Any color scheme in mind?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980068
$700?
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Motherboard: ASRock H81M-DGS R2.0 Micro ATX LGA1150 Motherboard  ($47.98 @ Newegg)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($69.88 @ OutletPC)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card  ($194.99 @ SuperBiiz)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($33.99 @ SuperBiiz)
Total: $678.68
Generated by PCPartPicker 2016-01-12 12:27 EST-0500
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980072
Hey guys!
I need some advice for a friend of mine.
He wants to build a PC from scratch. He has a keyboard, mouse and monitor.
The PC will be used for gaming. I really hope you guys can help me out!
With kind regards,
Tycho
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H81M-HD2 Micro ATX LGA1150 Motherboard  ($39.99 @ Micro Center)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($30.99 @ Newegg)
Video Card: Gigabyte Radeon R9 390 8GB Video Card  ($299.99 @ SuperBiiz)
Total: $697.43
Generated by PCPartPicker 2016-01-12 12:30 EST-0500
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980100
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($52.98 @ Newegg)
Video Card: PowerColor Radeon R9 390 8GB Video Card  ($293.98 @ Newegg)
Case: Xion XON-310_BK MicroATX Mid Tower Case  ($21.98 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $680.69
Wooo 390. Also, SSD later.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980107
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($188.99 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.88 @ OutletPC)
Case: Rosewill REDBONE ATX Mid Tower Case  ($44.99 @ Amazon)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($43.98 @ Newegg)
Total: $688.80
Generated by PCPartPicker 2016-01-12 12:50 EST-0500
Technically, all the builds that are basically just i5 with 8GB of RAM and R9 390 or 970 are also capable of running the Oculus Rift, if you were looking to buy one even at $600.
Edit: Better PSU.
CPU: AMD 5800X
GPU: Gigabyte Aorus 3070 Ti
SSD: WD SN850X 4TB x2
MoBo: Gigabyte Aorus Master B550
Case: Fractal Torrent
PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980167
Listen to the people who are telling you to get an r9 390.  An r9 390 kicks the 960's ass.
of course it does...it's twice as expensive.
I would not cut corners all over the place in order to fit an R9 390...his budget clearly good for an R9 380 or 380X along with a core i5 and a decent H97 motherboard though.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980179
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.99 @ Newegg)
Total: $679.81
Generated by PCPartPicker 2016-01-12 12:37 EST-0500
that PSU can't power that GPU it's only 38A on the 12v rail.
it's way too cheap.
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980187
Hey guys!
With kind regards,
Tycho
Go with a A88X platform and build from there.  If you want a specific build send me a message and I'll send something back within a day.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980188
Total: $679.81
CX PSU. Rip.
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980195
What? Why would you even try to build an FM2+ system at the 700$ price range.
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980208
Total: $706.80
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980229
Oh and if you want Skylake:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($199.98 @ OutletPC)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard  ($51.98 @ Newegg)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($34.99 @ Newegg)
Total: $704.78
Generated by PCPartPicker 2016-01-12 12:46 EST-0500
If you don't posts #4 and #5 have good lists.
PCPartPicker part list / Price breakdown by merchant
Total: $706.80
Just saying, the NEX series of PSU are like G1 and B1 and such... to be avoided.
USEFUL LINKS:
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980249
CX PSU. Rip.
it's way too cheap.
Whoops, didn't notice. Was an adaptation of a cheaper build. Guess I forgot that I had that on there. I'll edit that out.
CPU: AMD 5800X
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980264
Total: $706.80
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980274
hey there little genius...those EVGA psu are budget options they are by no means dangerous or bad or ''to be avoided'' or any other shit like that they are decent budget options and i would use one in my own build any day of the week.
Cheaping out on motherboard and memory configuration just to fit an higher end graphics card is not a good idea IMHO my build features an MSI Z170 motherboard for overclocking and dual channel 2400mhz memory so a much better system overall with a weaker graphics card sure but he can upgrade that later and get much better performance out of this kit...and the 380X is no sloutch either it can run games at 1080p with ease. :)
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980298
you don't get it...this motherboard will allow him to run his CPU at different base clockspeed therefore allow overclocking for both the CPU and memory...here listen to this video here ( i suggest you listen to the entire video...it's 15min. long but you'll learn a lot):
with skylake, you don't need a ''K'' chip for overclocking, you just need the good motherboard...and this one i picked is a good board for that.
another quick video more focused on increased gaming performance with the skylake overclocked ''locked'' processor:
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6980306
Quite agreesive, ain't we?
Chill out.
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6981214
Thanks you guys! You're amazing!
Total: $706.80
Love you guys! Thanks a lot!
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6983089
Total: $706.80
for future upgrades to this machine you might want to add an SSD and a better CPU cooler in the future. I would recommend a cooler master hyper 212 these are around 30$ more or less...it's worth it it would be quieter and you could change the baseclock of the CPU a bit without worying too much about temps...and the SSD with 240gb should be good to install windows and your programs on it and it will be much faster.
https://linustechtips.com/topic/525913-build-a-pc-with-700/#findComment-6986940
