Pop it open and disconnected the thing
Or just send it back to newegg and buy a different psu :)
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
Not without tasking apart the PSU, which is dangerous in itself. The LED is almost certainly on the fan, so the easiest way is probably to replace the fan. Only do it if you know what you're doing with PSUs, though
Is it safe to have that PSU in a house?
ROFL
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152047
is there a safe method of disabling the led on this power supply?
You would need to replace the fan looks like and LED fan but that isn't a good quality PSU, it would be best to replace it with something better.
The best way to disable it is by using it for a few more weeks and letting it catch on fire :P
Check out the PSU whitelist in my sig and be on your way!
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
