Decent card for Witcher 3?
Go to solution Solved by stealth80,
AMD 390, grab an aftermarket version from Sapphire
what is your budget?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
How much you got to spend? What display?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Ryzen Ram Guide
Random question, does it compare equally to the 290x?
290X is slightly faster
but the 390 runs cooler
Witcher 3 only uses 1500mb of vram
Rig: CPU: Intel I7 4790k @ 4.5 ghz | MOBO: MSI Z97 Gaming 3 | RAM: 4x4 gigs Kingston Fury 1600 ddr3 | GPU: MSI Geforce GTX 1070 Gaming X PSU: Seasonic M12ii-620 Evo Edition | HDD: 1 TB WD, 500 GB WD | SSD: Kingston SSD now 240 and 120 GB CASE: In Win 303 RGB edition | Mouse: Corsair m65 pro | Keyboard: Roccat Ryos MK | Headset: Hyper X Cloud Pro  | Monitor: LG 29um58-P Ultrawide monitor.
The last Patch fucked up the Performance alot. I hope they will fix this mess.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
GTX 970 is your best bet.
From Techpowerup's R9 Fury review:
Anything pre-November is invalid as that's when the new drivers hit and increased performance drastically
What's a decent card for witcher 3?
R9 390
R9 390
By 1.5% in Witcher 3 at 1080p on the Fury X (blue = 900p, red = 1080p, green = 1440p, purple = 4k), so the 970 probably still wins since it had a 7.5% lead on the Catalyst drivers.
Talking Crimson WHQL which came out mid-November.
With Essenthy's Super Turbo Lighting Mod and everything off/on low besides V-sync, Bloom, AA, HBAO+, textures (high), detail (high), and flora visibility range (high) I'm still seeing a solid 60FPS on my GTX 960, and the game looks like it did in the E3 2014 demo. Even without the mod, the settings turned to low have almost no noticeable visual impact.
Everyone thinks The Witcher 3 is borderline impossible to run, and criticizes the NVidia Hairworks feature because it crushes performance and does almost nothing. The truth is, almost all of the settings in The Witcher 3 do this (namely Water, Shadows, and Grass Density, which have NO visible impact whatsoever). The Witcher 3 is, in fact, very easy to run when you lower these settings.
This means you should be able to get a consistent 60FPS with these settings with a 390/970 at 1440p and a Fury X2/980ti at 4k.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
Crimson WHQL is Crimson 15.13, not 15.11. Not valid.
Stop, please stop. You're moving the goal post and don't even own the 390 nor have you ever. The Crimson driver suck, Crimson itself is awesome but the drivers fucking suck. For every fps they offer they take something in return. Be that lack of smoothness or crashes.
If anyone asks you never saw me.
