one computer in the house is connected directly to the router and getting 50mb/s speed test which is great exactly what i want.
but my computer is a little bit far. the road to the router is like :
Router |Concrete wall| a room | Concrete wall | my room
and im only getting 5 mb/s via WiFi
what should i do guys? please , i cant move the router to my room its gonna give me brain cancer :P all tha radiation bro
oh and by the way , i found this video :
do you think its legit?
thanks in advance!
https://linustechtips.com/topic/514420-i-need-a-solution/
Moving the router would not give you brain cancer... Just get a signal extender and place that in the room inbetween.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6845227
there are more rooms after mine so i might put the extender in my room , will that do any good? or i should just move the router to my room i dont know man
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6845278
ethernet to each room and put a small AP in bridge mode in each room.
each room will get full speed wifi
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6845341
your best bet is a powerline adapter
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6845342
it did not , it costs 50$ , how do you know its a joke man? i have to get something like that i dont know what to do with my home network.. one computer got 50mb , all the other got 1mb
Think about what you're saying!!
You're having problems with the signal strength as it is and you want to place your router in a box that will block 90% of rf emissions.
Just let that sink in for a minute.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6845821
I know it sounds stupid man but i thought i can put the router in my room with that box so i wont get exposed.. I dont know what to do man, maybe my pc need a better network adapter? I have no clue thats why im asking you guys..
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6845970
Get exposed to what? wifi? C'mon, let's get real now. You sound like one of those people that refuse to eat food that was in a microwave because of the "radiation".
Electromagnetic waves, radio waves, rf radiation; it's all the same thing. It is what is called non-ionizing radiation. It does not give you brain cancer.
You're thinking of ionizing radiation. That would be UV, X-rays and gamma rays.
Read this: https://en.wikipedia.org/wiki/Non-ionizing_radiation
Once you're done that, put the router in your room and enjoy your perfect wireless connection.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6846749
My house has 3 APs, one in my bedroom, two mainfloor, and i sleep w my phone next to my bed. i guess i will get cancer.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6846821
The RF transmission strength from Cellphone Towers (3G/4G etc), AM/FM radio and TV is much stronger than a small WiFi access point. You could tape an access point to your head permanently and you would sooner die from be struck by a car while crossing the road, due to the access point blocking your view.
Everything that uses or generates electricity emits some form of electromagnetic radiation, this is a simple fact of modern life and is inescapable unless you go live under a rock far out in the middle of nowhere.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6847796
Time to seek professional help as your EM radiation phobia is impacting severely on your life. This is an intervention by a random stranger, you need help.
k thanks guys , i might actually do that and put the router on my desk , but i would like to try powerline adapter is that any good?
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6848028
Powerline adapters are usually a method of last resort. If you can put the router in your room, just put it there.
My brother is afraid the radiation will hurt me, because i aleardy had cancer so thats why its an issue.. Ill probqbly get the powerline =)
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6850271
I'm sorry you that you had to suffer that and I'm glad that you were able to pull through.
Being ignorant of the truth does not help anybody. It's like thinking that you get the flu from going outside on a cold day with no jacket; if that's your thinking, you'll never stop to think about proper handwashing and taking care in public places and so you'll continue catching the flu every year.
Radio waves have not ever, nor will they ever cause anybody to have cancer. Human physiology simply does not work like that.
Your brother worries about the radio waves causing cancer...does he worry about the thousands of known carcinogenic chemicals that you probably have in your home this very moment? Does he make you put on sunscreen every time you go onto into the sun to protect you from the KNOWN cancer causing UV radiation from the sun?
You do whatever you want, but this idea of perpetuating ignorance to appease the ignorant is killing progress in modern society.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6852540
ok man i hear you.. but if i want to convince my brother to get me something , would it be better to get a powerline or my router in my room? who has less radiation?
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6853536
Powerline Adapter - Save the receipt and don't damage the box when opening in case it doesn't work for you.
Don't waste money on range extenders, chances are no one in your home even knows how to configure your current router correctly, nothing worse than adding another router into the mix. Powerline adapters are plug-and-play, or at most require pushing a single button on each end.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6854086
Again I urge you to get professional help for the phobia, its severely impacting your quality of life. You need the sort of help only a medical professional can provide, I can appreciate how you got there but while the cancer was cured your view of the world has not survived unscathed and needs treatment.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6856426
yeah thanks man , its probably not as dangerous as i think.. and i have a therapist , i just didn't discussed that topic with her yet.
https://linustechtips.com/topic/514420-i-need-a-solution/#findComment-6884608
