Hello
So I have MSI X99 Godlike, 5930K, Corsair Dominator 32GB 3000Mhz and EK Predator 360mm
When I tried my 4.4Ghz overclock using 125.00Mhz BLCK and 1.3V I got crashes in games and Intel Burn Test says my overclock in unstable. So I went back to stock core clocks and kept my 125.00Mhz (as my RAM needs it) however during Intel Burn Test my system froze twice and then the third time it said unstable overclock.
Temperatures for both overclocked and stock are fine (71c highest stock and 85c highest overclock, however it normally is around 76c)
Could I have some help please.
Thanks
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
https://linustechtips.com/topic/513419-5930k-overclocking-help/
I agree with @Ronnie76. You can't OC with BLCK on haswell, you need to overclock using the multiplier and bumping up the voltage when needed.
I just realized how many things is wrong with haswell
It doesn't play nice with Voltage, you can't BLCK OC, and it feels like Im forgetting something...
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6835857
and you can only overclock the K-skews unlike skylake where you can overclock i3s? On top of that mainstream haswell CPUs have a horrible TIM that make the CPUs get really hot.
oh yeah and they "Fixed that with Devils Canyon"
Still I have no comment on the Skylake i3 Overclocking xD
You could also count the overclockable Pentium strange and off too
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6835913
This is LGA2011 not LGA1150
Running 1.25 platform (125.00 BLCK) is required for most XMP kits of DDR4. Most boards set it to 1.25 automatically.
@Metro have you tried the Intel XTU stress test?
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6835927
Haswell-E not Broadwell-E
still the same generation just different chipset, same architecture.
~js
Do a bit of research..
Haswell-E i.e. LGA2011 requires use of a 1.25 multiplier to run high speed XMP DDR4 kits
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6835951
Who said the user had XMP enabled?
Regardless, mainstream haswell still ran really hot.
To be honest, I'm not that fond of having my CPU at STOCK SPEEDS with my h100i at 63~ deg Celsius under full load from AIDA64.
It seems way too hot, I agree with you there.
edit: Yeah, Haswell runs too hot 1.35 volts
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6835979
The Z170 spec includes a dedicated BLCK generator that's why. It's not tied to other system buses.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6835984
He's running 3000MHz it's a pretty safe assumption considering the JEDEC standard is 2133-C15.
And if you knew about the Haswell-E/X99 platform you'd know that XMP will automatically set your base to 125 if you go for a high RAM speed. Hence why OP is running 125.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6836028
Hello
Thanks for the responses, I have not tried XTU stress test. I will do it now.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6836237
Hello
It would be worth a go. It's a bit more reliable than Linpack (IBT) and covers the instruction sets better in modern CPUs.
Are you sure you don't just need to up the voltage of the CPU? You do have some temp headroom.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6836241
Do you mean at stock or when overclocked, as it my computer crashes on both.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6836260
Hmm.
Is this only with 125 base?
Will leaving it at 100 and running your RAM at the standard 2133-C15 cause a crash in XTU?
A lot of people increase the 'system agent' voltage when they are running 125 & 3000MHz.
I think Tweaktown did a preppy comprehensive article on X99 & high speed DDR4 platform clocking a while back.
Give me a moment and I'll try dig it up.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6836282
Hmm.
So I tried Intel Extreme Tuning both CPU and memory stress test for 15 minutes and it gave me no crashes or stability problems.
It is only with 125Mhz, clock speed is at stock clocks. Could Intel Burn test be the problem for it having stability problems without overclock.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6836496
The Linpack test is pretty old. I'd just do an hour on XTU then start dialing things back up again. :)
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6836717
So I done CPU stress test on XTU for an hour, it was fine, on stock clocks with BCLK 125.00Mhz. Then I done memory stress test and got Kmode_Exception_not_handled Windows 10 error.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6837565
I'd try running memtestx86, you'll need a USB drive to run it from.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6837570
Yeah, I just got two Windows 10 blue screens when testing memory with XTU, so I think my RAM is bad
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6837607
I will try memtestx86 now.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6837610
You'll likely need to increase the system agent voltage if you're running 125MHz BClk.
~js
Haswell-E and Broadwell-E are both on the X99 Chipset using the LGA2011v3 socket.
Haswell-E (i.e. i7 5820K, 5930K, 5960X) supports base-clock overclocking, which is REQUIRED to run RAM kits at clock speeds above 2666MHz.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6838545
It came back with no errors. So now I am not sure what is going on.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6838685
Hmm.
Gotta keep it interesting.
I'll get back to you in the morning with any ideas.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6838762
Hmm.
I will do another memtest86 later and will do the UEFI version as well
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6839195
Slight increases to the VCCIO (also known as VCCIN VTT on some motherboards) and the System Agent voltages should increase the stability of the IMC when running high-speed RAM. I haven't overclocked my memory higher than 2666 (I'll be honest, the RAM did that all by itself too) so I don't have any values to aim at for those two settings though.
https://linustechtips.com/topic/513419-5930k-overclocking-help/#findComment-6839213
