Hey guys, i would like to receive some feedback about this pre built i ve made. I would like to mention that i am gonna use this computer for gaming adn engineering stuff. If i am missing something, please let me know ( i already have a mic, a keyboard, a mouse and a headset) . And i would also add that i am paying for all these, so i want to use my money wisely
Thanks.
Intel Core i5-4690K 3.5GHz Quad-Core Processor
Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler
MSI Z97-GAMING 5 ATX LGA1150 Motherboard
Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory
Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card
Corsair SPEC-03 Red ATX Mid Tower Case
Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
LG GH24NS95 DVD/CD Writer
Asus VE228H 21.5" Monitor
https://linustechtips.com/topic/510135-my-first-built-computer-help/
Thanks.
Budget?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($213.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-Gaming 3 ATX LGA1150 Motherboard  ($104.99 @ SuperBiiz)
Video Card: MSI Radeon R9 390 8GB Video Card  ($319.98 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($59.99 @ Micro Center)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($25.00)
Total: $1000.78
Generated by PCPartPicker 2015-12-21 18:39 EST-0500
Total: $1000.78
Pretty much this^ with the only changes I'd make: dropping the 4690k in favor of the Xeon E3-1231v3, which saves some money on a cooler, motherboard and direct that money into a monitor which OP needs.
So basically this:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
Motherboard: MSI B85-G43 GAMING ATX LGA1150 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill Sniper Series 16GB (2 x 8GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($44.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($293.98 @ Newegg)
Case: Fractal Design Define S ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($56.99 @ Amazon)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor  ($129.00 @ Amazon)
Total: $1002.90
Generated by PCPartPicker 2015-12-21 18:46 EST-0500
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
$1025:
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($75.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($29.99 @ Newegg)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive  ($127.99 @ NCIX US)
Case: Thermaltake Versa H22 ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Case Fan: Kingwin CF-012LBR 40.0 CFM 120mm  Fan  ($3.98 @ OutletPC)
Monitor: Acer R240HY bidx 60Hz 23.8" Monitor  ($129.99 @ Amazon)
Total: $994.87
Generated by PCPartPicker 2015-12-21 18:52 EST-0500
So basically this:
Total: $1002.90
One up:
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.99 @ SuperBiiz)
Storage: PNY CS1211 240GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Video Card: PNY GeForce GTX 970 4GB Video Card  ($293.98 @ Newegg)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor  ($79.99 @ Amazon)
Total: $998.29
970 for CUDA since he is in engineering.
-snip-
If that's what he needs, sure, the 970 would be good ^^
-snip-
A 520W PSU with a 390 is pushing it imo, just get a higher-wattage one to have some overclocking headroom perhaps?
More RAM will be useful in engineering
A SSD for programs like Inventor (Just using this as an example) that take a decent amount of time to load
EVGA G2 PSU instead of CX
cx series is a no-no
Why not CX series? I thought they were excellent
He won't even hit 92% usage, and will hardly ever hit that mark... but I get what you mean.
Give 300W to the R9 390.  480W on the 12v rail.  That is 180W for the system.  It scrapes by =P
One up:
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.88 @ OutletPC)
Case: Thermaltake Core V21 MicroATX Mini Tower Case ($55.98 @ Newegg)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($61.50 @ Newegg)
Total: $998.29
Xeon E3 is better than i5 4690k?
Bad capacitors that, when under load, have a reasonably high chance of exploding. This, in turn, can damage components in your PC. Invest in a good PSU now, so you won't have to replace dead components later.
They're not even close to that... Not good for high-end GPUs.
It's faster, and more powerful overall, it has lower single-core performance but that shouldn't matter much since you're getting hyperthreading instead
For engineering. The hyperthreading will wreck the 4690K in rendering and it doesn't do too badly in gaming either. It has a higher IPC because it's better binned (being a Xeon and all), so at 3.4GHz it is comparable to a non-OC' ed 4690K.
Actually, the 1231 has better single core performance at stock speeds in comparison to a 4690K due to a better binning process.
Well, I'm assuming he'll overclock, nobody would buy a Z97 + 212 Evo + 4690k and leave it at stock speeds...
The Xeon gets a boost when a program can use more than four cores.  We are just guessing that you will need more multi-threaded support and that you do not like to overclock.
We are sort of phishing for you to respond.
Thanks man.
One more question , doesnt x3 need CPU cooler, really?
