 For some reason my settings all defaulted to absolute max resulting in higher than usual temps and almost giving me a heart attack. Anyone else noticing this?
https://linustechtips.com/topic/506657-csgo-settings/
it's the new feature
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762567
new update has auto setting for graphics options.
haven't noticed temp changes.
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762577
Maybe because they rolled back the last patch?
you can imagine my jaw dropping when I saw that instead of 72*C I was getting 82*C on the CPU lol
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762584
I got a laptop :P - difference between 20% load and 60% load on all 8 CPU threads is vast
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762588
Heh, I run it at max anyways, so I wouldn't know. :P
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762598
With a giant radiator on my GPU temps barely hit 38C. So if there's 'temp changes' they are hugely unnoticed.
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762609
Ah that makes a difference
Yes indeed - I have 200 fps either way, but one way gives me 10*C less for focusing all the load on one core :D
I have a fairly decent copper heatsink. Enough for the 860M and i7 :D
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762629
Nope, mine is still the same :)
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762631
Out of curiosity how well do you like your Y50?
I've heard the build quality isn't to die for
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762667
Hmmmm I really am bottlenecked by my CPU  :lol:
Echelon Mk 2.11
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762674
I like it quite a bit - it's full metal with the exception of the hinge cover (like 99% of laptops) and it's VERY sturdy.
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762704
That sounds solid! I don't know why people would tell me it was flimsy :P
Hows the battery life?
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762723
2 hours of maxed brightness movies
3.25 hours of dim movies
1 hour of gaming
4 hours idling
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762727
Ouch. Im spoiled I suppose, but thats manageable :P
If I cared to undervolt the CPU and iGPU a bit and dimmed everything down and put it all on power saved (extra slowness) I could probably manage 5 hours of internet browsing
https://linustechtips.com/topic/506657-csgo-settings/#findComment-6762779
