One case fan to go (Help!)
didex
Hey guys, I have a zalman T4 case with one 92mm fan on the back and one 120mm fan on the front. I got one more 120mm fan from a friend but i dont know where to put it. The case have 2 spots to install the fans in the side panel. Wheres should i install them(intake or exhaust)? Note that the fan spots have dust filters installed already.(although they can be removed).
System: i3-4170, HD5750 OC
Case: http://www.thg.ru/technews/images/t4-051013.jpg
some more opinions would be nice :)
There isn't really any other place to put the fan aside from on the side and having it intake would be good.
