Hey guys, had a problem while playing BF3 the other day.
After a total of 2,5 rounds a Windows error message popped up saying that too much ram is used by BF3, and i had to close it. RAM usage at that time was 99%, after closing BF3, it immediately dropped down to the regular level of about 30%
Restartet BF and my RAM usage got up again to about 95%, is this normal? Can´t imagine that BF3 would need 5 GB of free RAM to work.. i mean, that would be a quarter of all the game files (21GB) in total.
Sys specs:
i5-2400
8 GB DDR 3 Ram
HD 7850 2GB (Catalyst 13.8 Beta)
Win 7 64
https://linustechtips.com/topic/50117-battlefield-3-ram-usage-problem/
It may be just a memory leak. Try reinstalling the game and/or drivers.
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
That is totally normal, when i play FC3 i use about 9GB of RAM
BF3 is a 32-bit program so it cant address more than 4GB's.  You have to have a memory leak somewhere.... not necessarily from BF3 though. Try leaving the Task Manager processes windows in real time so you can see where the leak is coming from.
i5-3570K @4.2ghz | Gigabyte Z77-DS3H | 16GB G. Skill Ripjaw 1600mhz 9-9-9-24 (2x8GB) | 120GB Vertex 3/640GB WD 7200RPM | AMD HD7950 @ 1025mhz | 600W Corsair CS600 | Hyper 212 CPU Cooler | 5x 120mm fans 79cfm | Ultra Defender Case
Hm...the problem fixed itself. Moved the BF3 files to my SSD to shorten loading time and retried, everything seems to be fine. RAM usage at full 64 player server was at 45%
Maybe there was a corrupt game file or something that got repaired by the moving/fake reinstallation...
Thanks anyways.
Thats funny as i could max the game out back when i had only 4gb ram. 1.5gb was free before starting a game.
Listen if you care.
And here we go again, haven´t played since the last post. Yesterday i tried it again and bam, BF3 crashes everything down. Different Win error msg though. Last time it told: Battlefield is using to much Ram an needs to be shut down. This time it just says that i havent enough Ram, i should close everything and restart.
Also a DirectX error.
What should i try? Re-Roll to an older graphics driver?
Also, where does that atiedxx.exe come from? Is that part of the CCC?
bf3 only uses arround 1 GB (less or more depending on maps ). if it goes above 2GB that is impossible and there is 100% a problem
1.4 GB is possible in rare scenarios.
very rare scenarios.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
What exactly does FC3 and your RAM usage have to do with BF3 and RAM usage in this specific scenario??
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
I just wanted to tell that it is normal... :(
No, was not normal at all -BF3 and FC3 are very different, not to mention that BF3 is a 32 bit app, not sure about FC3. Also, I would think if your FC3 is using 9GB of ram, you also have a memory leak...
Ok, sorry.
Ok, sorry.
The main point is to stay on topic as your original post could be seen as trolling.
Thanks!
Sorry, i don´t get what you mean, what german stuff?
on your Microsoft error message its in german, your german I dont know what it says. Anyway that doesnt matter a clean install after a full format of your c drive should fix any otherproblems your having, then redownload and install the drivers
Sys specs:
i5-2400
8 GB DDR 3 Ram
Win 7 64
I only have 4gb of ram and i play with chrome open and max i get is 90% RAM usage
I would check the memory using Memtest86+ if I were you.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Try closing Steam to the taskbar if you have that open. That fixed it for me.
Nope, steam was closed all the time.
However, after completely re-downloading and reinstalling the 21 GB game files and the firefox addon, it seems that battlelog now also f*#ks up my firefox(random crashes while i was in my Battlelog profile).
Played 2 rounds today, now BF3 crashes at starting screen.
Since i´ve never had any problems with other demanding games or applications i´ll go for the easiest solution ---> Deinstall Origin,BF and all the other crap that comes with it.
Don´t have the patience to deal with that kind of BS for that game.
