Anker is a reputable company, so the cells will be genuine.
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/500613-portable-charger-help/#findComment-6684689
I just bought an aukey 5 port one for $25cad a few days ago, and its great
EDIT- btw thats not a battery one though, this is a wall power charger
but the quality is great, maybe they make battery ones too
https://linustechtips.com/topic/500613-portable-charger-help/#findComment-6684703
hay guys i want a good portable charger to charge my ipad mini and my iphone 5, any ideas? (it needs to be 20$ or less) and is this a good one http://www.newegg.com/Product/Product.aspx?Item=N82E16875968071
Yes Anker is a good one for portable battery packs, and will be able to charge both those devices:
http://www.ianker.com/product/79AN13K2-BA#ptop
https://linustechtips.com/topic/500613-portable-charger-help/#findComment-6684741
