Broadwell E is coming very soon, using X99 and DDR4 still. Skylake E is still a way off.
Other systems I've built:
https://linustechtips.com/topic/500433-skylake-extreme-i7/#findComment-6682669
Skylake-E won't be out for a while, it's Broadwell-E that's out soon and that's on X99.
Broadwell-E is 6960X? 5960X is the Haswell-E? (I'm really not sure)
┏(◑̃.◑̃)┛ Totally Not Dangerous ┏(◐̃.◐̃)┛
i7 4790K / 16GB RAM \ 250GB SSD
https://linustechtips.com/topic/500433-skylake-extreme-i7/#findComment-6682683
I doubt it's coming soon but it wouldn't be on Socket 1151 if it did.
Likely Broadwell-E on X99.
Broadwell-E should be the 6960X but you never know with Intel.
https://linustechtips.com/topic/500433-skylake-extreme-i7/#findComment-6682684
Oh I see! I thought that 6xxx series was Skylake... heh Intel is weird. Heard it's going to have 10 cores right?
https://linustechtips.com/topic/500433-skylake-extreme-i7/#findComment-6682715
Doubt it.
And Intel always lag the enthusiast platform 1 architectural generation behind (e.g. 4xxx extreme was Ivybridge-E and 5xxx Haswell-E). Still running Sandy-E myself :P
And they tend not to increase core counts until people are basically begging them to, it took them from Gulftown from 2010 until Haswell-E to go from 6 to 8 cores.
https://linustechtips.com/topic/500433-skylake-extreme-i7/#findComment-6682747
Doubt it.
Yes they are a bit laggy ironically! ^^ Thanks for the info, it helped!
https://linustechtips.com/topic/500433-skylake-extreme-i7/#findComment-6682931
Yep.  Broadwell-E is coming out Q2, so before or during Summer.  $1000 10-core, 20-thread part, and then I believe two 8-core parts and a six core part, or it may be two six cores and an eight core, but that'll be for X99 and new X99 boards.  Skylake-E will be on a brand new chipset all together, so no more X99 after Broadwell-E.
https://linustechtips.com/topic/500433-skylake-extreme-i7/#findComment-6682947
That's pretty cool! :)
https://linustechtips.com/topic/500433-skylake-extreme-i7/#findComment-6683053
