CPU temps
Solved by ThinkWithPortals,
Sure . Any tip when remounting?
Basically, take extra care when doing it to ensure you do it correctly and see if that fixes it. If it still doesn't fix it, the pump in the waterblock could be defective and an RMA might be in order.
Issac Zachary ·
Posted in Troubleshooting1 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
play_circle_filled
Latest From ShortCircuit:
