Christmas Build Help
Solved by brob,
Thank you!
Okay, I've done a little research and I made some changes. I added a fully-modular PSU so I could remove any extra cords, I decided I want to upgrade to a 980, and changed to just a little different case.
How does it look?
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($254.99 @ Amazon)CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler ($94.99 @ Newegg)Motherboard: Gigabyte GA-Z170N-Gaming 5 Mini ITX LGA1151 Motherboard ($134.99 @ Amazon)Memory: G.Skill Ripjaws 4 series 16GB (2 x 8GB) DDR4-2400 Memory ($74.99 @ Newegg)Storage: OCZ Trion 100 240GB 2.5" Solid State Drive ($54.99 @ Amazon)Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.99 @ SuperBiiz)Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card ($429.99 @ Micro Center)Case: Corsair 250D Mini ITX Tower Case ($69.99 @ Micro Center)Power Supply: NZXT HALE82 V2 700W 80+ Bronze Certified Fully-Modular ATX Power Supply ($85.98 @ Newegg)Operating System: Microsoft Windows 10 Home OEM (64-bit) ($84.98 @ OutletPC)Total: $1331.88
The H105 is not compatible with the 250D. It is too thick. The H100i will fit. The H100i GTX will not fit without moding as it is 1mm longer and 3mm thicker than the H100i.
The psu is not very good.
The Seasonic G Series 650W unit on the other hand is excellent. Your build will use all three of the fixed cables on the SSR-650RM. One to the motherboard's 24-pin power connector. One to the 8-pin power connector. The third will provide power to the GTX 980.
