Good 27 Inch Monitor?
Lavish
Any good monitors that are 27 inch, Slim bezel, and at least 5ms (Not GTG) It would also be great for IPS but not required.
Max budget is 250, but would prefer 200 or less.
Intel i5 4690k | NZXT Kraken x61 | MSI z97 Gaming 5 | MSI GTX 970 EVGA Supernova G2 750 G-Skill Ripjaws 16GB 2133mhz [2x8] | Western Digital Caviar Blue 1TB HDD Samsung 850 EVO Series 250GB SSD NZXT H440 [black and Red]
Saving for a Dream rig :)
budget?
You missed a dell with 6ms response for 130 today, wasn't an amazing monitor but is was good and really cheap
Max of 250, but would prefer 200 or less.
For that kind of money, you'll only really be able to buy a 1080p monitor, and I cannot in good faith recommend any 27 inch monitor that is only 1080p, unless you plan on being at least 4-5 feet from it.
When in doubt, re-format.
would you instead recommend a 24 inch 144hz monitor thats 1080p
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236392&ignorebbr=1
it has everything besides a non-GTG refresh and isn't IPS
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
Yes.
Any nice ones you can recommend that have thin bezels.?
grab a korean monitor. They are great value for the money.
EDIT: nvm they aren't slim bezel
hello!
is it me you're looking for?
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
Cooler: Dark Rock Pro 3
RAM: 32GB DDR4
GPU: GTX 1080
Storage: 1TB 850 Evo, 1TB HDD, bunch of external hard drives
PSU: EVGA G2 750w
Peripherals: Logitech G502, Ducky One 711
Audio: Xonar U7, O2 amplifier (RIP), HD6XX
Monitors: 4k 24" Dell monitor, 1080p 24" Asus monitor
Laptop:
-Overkill Dell XPS
Fully maxed out early 2017 Dell XPS 15, GTX 1050 4GB, 7700HQ, 1TB nvme SSD, 32GB RAM, 4k display. 97Whr battery :x
Dell was having a $600 off sale for the fully specced out model, so I decided to get it :P
-Crapbook
Fully specced out early 2013 Macbook "pro" with gt 650m and constant 105c temperature on the CPU (GPU is 80-90C) when doing anything intensive...
A 2013 laptop with a regular sized battery still has better battery life than a 2017 laptop with a massive battery! I think this is a testament to apple's ability at making laptops, or maybe how little CPU technology has improved even 4+ years later (at least, until the recent introduction of 15W 4 core CPUs). Anyway, I'm never going to get a 35W CPU laptop again unless battery technology becomes ~5x better than as it is in 2018.
Apple knows how to make proper consumer-grade laptops (they don't know how to make pro laptops though). I guess this mostly software power efficiency related, but getting a mac makes perfect sense if you want a portable/powerful laptop that can do anything you want it to with great battery life.
