EVGA GS 850W arrived today, install it and the fans spin for a split second and turn off. What could it possibly be? First fully modular PSU also. Quote me also
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/494010-psu-help/
It prob wont help but I would check the connections EDIT:mabye you can check the manual
https://linustechtips.com/topic/494010-psu-help/#findComment-6614853
As said above, pretty sure that PSU wont even turn the fan on until you are at about 50% load, so dont expect it to be on most of the time.
When in doubt, re-format.
https://linustechtips.com/topic/494010-psu-help/#findComment-6614856
Mine does that. It's normal. The PSU runs without the fan 99% of the time.
https://linustechtips.com/topic/494010-psu-help/#findComment-6614878
Guess I should of started my PC doesn't turn on. CPU fan turns on for a short second and stops.
https://linustechtips.com/topic/494010-psu-help/#findComment-6614900
Try just reseating everything(taking all the plugs out and putting them back in). This catches a LOT of small errors that even experts occasionally run into.
A society's accepted views of the world surrounding said society is both the making and undoing of society itself.
“While one person hesitates because he feels inferior, the other is busy making mistakes and becoming superior.” - Henry C. Link
https://linustechtips.com/topic/494010-psu-help/#findComment-6614920
Ah, well in that case, make sure that everything is plugged in correctly, (both the 24 pin mobo and the 8 pin cpu cables from the PSU)
Are you able to get into your BIOS or is that not working either? Alsy try running with just a single stick of ram, this sometimes helps in troubleshooting things.
https://linustechtips.com/topic/494010-psu-help/#findComment-6614926
No BIOs.
I don't have time until Sunday so keep suggestions coming
https://linustechtips.com/topic/494010-psu-help/#findComment-6614970
Weird... Only thing I can recommend is making sure everything has been seated properly. Check the 24-pin connection to your PSU. It's a dumb design they used for it and I had trouble getting mine to start the first time.
https://linustechtips.com/topic/494010-psu-help/#findComment-6614982
Yeah the 24 pin mobo that goes into PSU is weird.
https://linustechtips.com/topic/494010-psu-help/#findComment-6614994
All of the Supernova power supplies I've bought came with a plug to connect to the motherboard cable in order to test the PSU.  It shorts two pins that turn it on.
Granted, none of them are GS models.  Does the GS come with this plug?  If so, use it.
https://linustechtips.com/topic/494010-psu-help/#findComment-6617113
Yeah it comes with it
https://linustechtips.com/topic/494010-psu-help/#findComment-6617165
