Help me with PC Build
Go to solution Solved by ShoMy,
Tnx dude..
Hi,
Am newbie at PC's,i know some thing but that isn't enough for PC builder so i need some good advices...
This is setup that i thought buying
RAM Crucial Ballistix Sport 8GB - about 70$
Motherboard AsRock z97 Extreme 3 - about 140$
HDD 1Tb Seagate Barracuda - about 50$
Graphic Card Radeon R9 380 2Gb - about 150$
PSU Raidmax Cobra 500w 80+ Bronze sertified - about 50$
CPU AMD FX 6300 - about 100$
I need some advices how to lower the price,some cheaper alternatives for motherboard,graphic card..
Keep on mind that standard in my country is like double,for example avg. payment in USA is 800$,in my country it is 400$ (not really,but somenthing like that)
So it's like components cost double in my country than in USA.
Thanks for any help :)
https://linustechtips.com/topic/492366-help-me-with-pc-build/
Welcome to the Forum.
Please don't use that power supply - I'm surprised it's certified as even Bronze efficiency. Raidmax makes only crap IIRC.
Also, if a core i3 will fit into your budget please go with that over the FX-6300.
Sig under construction.
https://linustechtips.com/topic/492366-help-me-with-pc-build/#findComment-6600071
Hi,
Try to go on Amazon you should be able to get the RAM for ~$40  :)
                             Current PC Specs
                       GPU: 750ti CPU: AMD FX-6300 PSU: EVGA 500W Case: Corsair Carbide Series Windowed 100R Mobo: Gigabyte GA-970A-DS3P
https://linustechtips.com/topic/492366-help-me-with-pc-build/#findComment-6600100
-snip-
welcome to the forums.
keep in mind the cpu you chose doesnt fit in the mobo you picked.
here is what i would suggest for the money. try giving us a real budget if you want us to help further (like 600euros or w/e)
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($69.88 @ OutletPC)
Motherboard: Asus A88XM-A Micro ATX FM2+ Motherboard  ($39.99 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory  ($34.99 @ Newegg)
Storage: OCZ Trion 100 120GB 2.5" Solid State Drive  ($34.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($39.10 @ SuperBiiz)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($159.99 @ Newegg)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($30.99 @ Newegg)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply  ($39.99 @ Newegg)
Total: $449.92
Generated by PCPartPicker 2015-11-25 16:11 EST-0500
The site has changed....
https://linustechtips.com/topic/492366-help-me-with-pc-build/#findComment-6600121
Am from Bosnia and Heregovina,my courency is BAM
PSU i consider buying was Corsair CX 500w PSU
@Tedster why is core I3 better than FX?
@jimakos234 i like build you made on Pc part picker.
Amazon doesn't ship in my country,thats one more thing i wanted to mention...
https://linustechtips.com/topic/492366-help-me-with-pc-build/#findComment-6603917
Hi,
I would really recommend using PCpartpicker.
https://linustechtips.com/topic/492366-help-me-with-pc-build/#findComment-6606354
@jimakos1234 is there any chance to fit i3 540 in this motherboard or similar,I managed to find this processor for 30 euros?
I3 540? That's like 5 years old.... I mean it'll work but fx 6300 or other stuff will be much better. I don't even know if you can find a motherboard that's actually compatible with it...
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/492366-help-me-with-pc-build/#findComment-6615255
