Best way to clean a headset?
Axno
I have the Logitech G35 which has earpads that aren't removable. What's my best option? Rubbing alc or hand sanitizer on a soft cloth and wait for it to dry? I don't know anything about cleaning headsets so yeah any help is appreciated.
Throw it in with the dark clothes, cold water, a little fabric softener, let it dry on it's own no dryer.
Dont do this...
Use 99% isopropyl alcohol, and a cloth (Microfiber maybe)
 - or -
Use a Lens cleansing wipe
Why would you throw a headset in a washing machine...wtf
Contact logitech for warranty replacement, or buy real headphones that don't SUCK ASS.
IN theory it should be fine, if rinsed throughougly with distiled water, and let to dry for a long time
no...
drivers are made of paper...
the speaker cones would just dissolve in water
no...
right, right.
Not all drivers are made of paper, or are they in headphones?
right, right.
i have seen some made of plastic, but those were cheap $10 logitech crap headphones
What was in my K7xx didnt look paper.
And speakers dont use paper
they actually mix paper with resin and all kinds of stuff
very few speakers are made with kevlar and fiberglass and aluminum
most are paper
Usually they're made of Mylar.
I wouldn't recommend washing them though, the diaphragms are so thin they might get damaged, and it'll also likely leave residue that messes with the acoustics of the thing.
You could use dry cleaning spray.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
Also, for cleaning, you can try some antibacterial cleaning wipes or using a paper towel and water.
Post of the day!
MSI Z97M Gaming | i7-4790k | NZXT Kraken X61 | 16GB Kingston Savage DDR3 2400
EVGA GTX1080 Ti FTW3 | EVGA G2 750 | Phanteks Enthoo Evolv | 1TB 850 Evo | 2TB 860 Evo | 22TB DS918+
Scarlett 2i2 | WooAudio WA7 Fireflies | Fostex TR-X00 | Beyer DT990 | MrSpeaker Alpha Dog | V-Moda M-100 | JBL LSR305 MK2
Use an industrial strength vacuum cleaner on that shizzz.
most are paper
Not headphone drivers.
spwath said "speakers"
Even then, plenty are polyproplene or some other synthetic.
the huge majority of speakers are paper, or a synthetic/paper combo
for decades in the past speakers were only made out of paper
Sure, old speakers are paper, but newer are not
We'll need verification.
https://en.wikipedia.org/wiki/Diaphragm_(acoustics)
https://en.wikipedia.org/wiki/Speaker_driver
yeah older ones were almost all paper, newer speakers are STILL almost all paper
pretty much all PA speakers use paper cones
a lot of home theater speakers use paper cones, as well as subwoofer for home or car
it doesnt look like it, but a lot of speakers are still paper
$(KGrHqZ,!lwE6C-LNtpBBOk2by)5!!~~_35.JPGyes this is still paper
