H80i is a good mid-range cooler which fits pretty much all cases and keeps CPU's which arent rocking a crazy OC very cold :)
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/488139-i-need-a-cpu-watercooler/#findComment-6551502
x61 or h100i gtx
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/488139-i-need-a-cpu-watercooler/#findComment-6551543
Most 2x140mm AIO like the Kraken X61 will not fit in the CM Storm Trooper. Nzxt indicates that only the Kraken X31 & X41 are compatible.
You might consider a very good air tower cooler like Noctua NH-D15, Noctua NH-D14, or Noctua NH-U12S.
https://linustechtips.com/topic/488139-i-need-a-cpu-watercooler/#findComment-6554033
I am guessing though, the H100i GTX will work just fine?
https://linustechtips.com/topic/488139-i-need-a-cpu-watercooler/#findComment-6555925
