Help understanding CPU MC and RAM voltages
Solved by Godlygamer23,
So this scenario is 1.5 vs 1.65, is that a lot? Also, even if it doesn't hurt anything, will be memory performance be decreased?
No, you should be fine.
CPU overclocking is affected by RAM overclocking. If clocks are higher on RAM, generally the CPU is able to achieve less of an overclock. And sometimes, the memory controllers can't handle memory overclocks at all.
