Triple monitor setup
LobsterJon
Looking to replace all three of my current monitors.
Desired specs:
21.5 inch
IPS Panel
1920x1080
DVI or Display Port
Vesa mount compatible
60Hz
Bonus:
Slim bezels
$200ish per monitor.
Any suggestions?
i dont know if its in your budget but get a 21:9 in the middle and two 16:9 on the end
My speakers dont even fit on or under my desk...PA's FTW
I have 2 HP ZR22w that fits all those specs besides the slim bezels. Not the best latency at 8ms however. I got them at $99 each refurbished.
Any suggestions?
What do you use the monitors for
these are the cheapest option and tbh fit the bill rather well: https://pcpartpicker.com/part/aoc-monitor-i2269vw
Actually the the first 3 in the above are better the above post are better.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
