Hey everyone I am in close to finishing my senior project and I have to showcase a product of the research I have done. My topic was on PC Cooling and the effect on Performance. I discussed air cooling, liquid cooling, and submersion. I am going to try to showcase a mineral oil pc and i was wondering how to cool the oil once it's in the tank? Figuring out how to cool it is giving me a hard time.
Any ideas?
Thanks all help is appreciated
https://linustechtips.com/topic/486759-mineral-oil-cooling/
An open pump system with a radiator grouping on the outside of the tank?
Just Google "Mineral Oil PC", Linus and Slick did a build log on it.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/486759-mineral-oil-cooling/#findComment-6532475
You pump it through a radiator and have fans mounted to the radiator.  No different than a regular water-cooling setup except you're circulating mineral oil.  Make sure whatever tubing you chose is marked as compatible with mineral oil (McMaster has the best filtering for this stuff).
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/486759-mineral-oil-cooling/#findComment-6532477
a radiator on the outside cools it
https://linustechtips.com/topic/486759-mineral-oil-cooling/#findComment-6532516
This. Google how to do it. MANY people of done this.
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/486759-mineral-oil-cooling/#findComment-6532521
Any ideas?
Welcome to the Forums!
For mineral oil cooling you basically need a radiator or way of dissipating the heat from the fluid into the air. One thing to mention is as others have pointed out you need to use the proper tubing and replace any rubber seals or orings with silicone based seals since mineral oil stiffens and deteriorates rubber orings over time.
https://linustechtips.com/topic/486759-mineral-oil-cooling/#findComment-6534904
Any ideas?
Wellcome!
I have an other suggestion. The box is supposed to be filled with oil.
post-216771-0-65225100-1447879137_thumb.
post-216771-0-74665100-1447879140_thumb.
post-216771-0-00170400-1447879144_thumb.
But the radiator and fan way is easier to do. Also look here:
https://www.youtube.com/playlist?list=PL8mG-RkN2uTxaG7pz3feWGG2AwCM-W4nG
Part 4 is Q&A.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/486759-mineral-oil-cooling/#findComment-6542741
