pc wont boot after i took battery out of mobo ?
Solved by Shiwoon,
Qflash options isn't even working then your only two option is to go to their support (can be found here http://www.gigabyte.us/support-downloads/technical-support.aspx) or buy a new mobo.
Since you've update your bios via their app center...
Also since they've made it, they should know a lot more than we do.
(this is why you should never update your mobo bios if there's nothing wrong with it... there's an old saying "if it aint broke, don't fix it")
