pc wont boot after i took battery out of mobo ?
newtopc
Go to solution Solved by Shiwoon,
Qflash options isn't even working then your only two option is to go to their support (can be found here http://www.gigabyte.us/support-downloads/technical-support.aspx) or buy a new mobo.
Since you've update your bios via their app center...
Also since they've made it, they should know a lot more than we do.
(this is why you should never update your mobo bios if there's nothing wrong with it... there's an old saying "if it aint broke, don't fix it")
ye tried it power button works fine
So it does post?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
From what i read, his computer do post but he can't get into the bios.
"tries to enter bios but screen just goes blank"
He don't need to get into bios to qflash... read the manual again... he can qflash from the bios menu but he can also qflash without enter bios..
I know, but I thought he said it wouldn't turn on at all.
yes when i updated the bios it wouldnt leave me into the bios since then i removed the cmos battery to see if that would fix it but now cant even boot into windows :(
See this @Shiwoon
I don't know if he can post or not.
He don't need to get into bios to qflash... read the manual again... he can qflash from the bios menu but he can also qflash without entering bios..
it comes on but the screen just goes blank i will try qflash with usb
QFlash will probably work. I just wanted to try something quicker to see if that would work, but I guess not.
no im open to anything i really really appreciate it guys youve being great
Do you see a screen like this or similar to this when you turn on your computer? If you can then you can qflash..
Or is the splash screen not even showing up?
If death has no cost, life has no worth
The dead are gone, the living are hungry
Life is not about finding yourself, it's about creating yourself.
yes but when i try it just goes blank ? its f6 on my mobo
sorry actually it mightnt be i will try anyway
it just goes blank when i try it :(
Which key did you press?
Try the "End" key.
ive tried f6 and end took out the hard drive incase it wasnt working cause my hdd is boot device the screen come up goes black with just the mouse cursor :(
ok thank you so much for the help
