Laptop CPU too hot!
Go to solution Solved by TheAmazingCookieFromSquare,
68-74*C for a laptop aint bad
My dads laptop goes to 81*C on his Ivy-Bridge i3 so no prob
Hey guys!
My laptop's idle temperature is always between 48-53 degrees celcius. Sometimes during the day one or another service or process uses about 25% of my cpu usage then the temperature shoot to between 68 and 74 degrees celcius.
I took my laptop apart the other day, cleaned out the vents and removed all the dust bunnies. I also removed the old cpu thermal paste and applied new thermal paste. I also checked the fan is working like it always has.
After I put the laptop together again a few days ago I've been keeping an eye on my laptop and It seems to be doing exactly the same.
I'm pretty out of ideas at this point, I was thinking that maybe this is just the normal temperature for my laptop to run at? What do you guys think?
The laptop is an Acer Aspire E1-571 with a Core i3 2328m processor and 8gb of ram, as well as a Samsung 850 EVO SSD. The laptop is about 2 and a half years old, i bought it in February 2013
99 little bugs in the code, 99 little bugs, you take one down, you pass it around... 10335 little bugs in the code :mellow:
Intel Core i7 3770, ASUS Maximus IV Gene-Z, DDR3 @1866MHz 16GB (2x8GB), GIGABYTE GTX 1060 G1 Gaming 6GB
https://linustechtips.com/topic/483107-laptop-cpu-too-hot/
The cooling is probably just shit. Laptops yaknow.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/483107-laptop-cpu-too-hot/#findComment-6480662
Insert   Dank   Signature   Here.
https://linustechtips.com/topic/483107-laptop-cpu-too-hot/#findComment-6480669
Hey guys!
YOU THINK THATS HOT??
my laptop is at 85C right now with like 15 tabs open
3 of them youtube
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
https://linustechtips.com/topic/483107-laptop-cpu-too-hot/#findComment-6480698
Mine reaches 90°C with arctic silver V, that's too hot, and not what you have :)
74 isn't bad.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/483107-laptop-cpu-too-hot/#findComment-6480707
I guess my CPU is also a golden chip since I get only about 52*C while browsing - then again - it depends on the model.
What laptop is yours? What CPU also?
https://linustechtips.com/topic/483107-laptop-cpu-too-hot/#findComment-6480722
Thanks a lot guys! I learn something new everyday on LinusTech :)
Cheers!
https://linustechtips.com/topic/483107-laptop-cpu-too-hot/#findComment-6485669
If the heat gets uncomfortable to the touch you can try a cooling pad to help with the circulation. They should cost around $20 or less. Another idea which might help is to stack the laptop on top of two equally thick books or blocks with a gap underneath to give the heat more room to disperse.
Edit: Currency is in AUD.
RAM: 8GB of male sheep
https://linustechtips.com/topic/483107-laptop-cpu-too-hot/#findComment-6485764
