Monitor
Arwanell
is this monitor good? http://www.lg.com/us/monitors/lg-25UM57-P-ultrawide-led-monitor
the price is nice
and how much will this resolution affect performance? much more than 1080p?
it doesn't affect performance much atleast i din't notice.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
the price is nice
Good monitor, but beware that a 25 inch ultrawide is only the same height as a 22 inch regular monitor, so just make sure you can deal with the reduced vertical height.
You'll have about 30% more pixels than 1080p.
Other systems I've built:
i have powerfull enough PC.
will it affect gaming? I mean, will there be things I can't see?
now i have 22' monitor, so that will be a nice upgrade
Just FYI, 25" for 21:9 resolution is really small. I'd suggest at least getting a 27" for 2560x1080 monitor. It shouldn't affect your performance by much, but what gpu do you have?
CPU - Intel i7-4790k | CPU Cooler - Cooler Master Hyper 212 EVO | Motherboard - Gigabyte GA-Z97-HD3 (Rev 2.0) | RAM - G.Skill Ripjaws X 16GB (2x8) DDR3-1866 | Storage - Samsung 850 EVO 500GB SSD | Graphics Card - EVGA GeForce GTX 980ti SC | Case - Fractal Design Define R5 w/Window (Black) | PSU - EVGA 750W B2 | Display - Acer K272HUL | Keyboard - E-Element RGB | Mouse - Logitech g502 | Sound - Klipsch ProMedia 2.1/Fostex TH-x00/Sennheiser HD595
What do you mean, "nice things I can't see?"
I don't really understand your question.
He has an R9 390, and I don't think the vertical height should matter too much as he's using a 22 inch monitor atm.
you said reduced vertical height, will there be cut picture in any games?
No, you just get to see more on the sides.
I think he is refering to the monitor itself in size it's not tall at all =P
okay, might buy 27' 1080p then, about the same price
