260x vs 250x: will it really make that much of a difference?
So, in another topic, I was talking about making my own server and such, and I decided the best chip to go with would be the amd athlon x4 860k (over the pentium I was offered). I need to couple it with a dGPU (I was going to anyway...), and I found two that are in my price-range. I kinda didn't go to far beyond the realm of 2013, so gtx 600 series and radeon hd weren't quite as looked through... And after looking at the gtx 750's pricing, I just said to heck with it. I'm going to keep choices down to 2.
Anyway, I am looking at a refurbished sapphire r7 260x (1GB GDDR5) and a new powercolor r7 250x (2GB GDDR5 <-- very important to take note of). The Sapphire is more expensive at $15 (after rebate), which made me wonder, is it really all that much better?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202130
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131662
Experience or just speculation is welcomed. I also want to buy this thing soon, so I can catch the rebate it I do end up picking the 250x.
Thnx in advance.
--robinspi
There is not a huge difference between the two in performance but if they are the same price or within $10-$15 of each other the R7 260X is definitely worth buying as long as it's the 2GB version. The 250X = HD 7770 and the 260X = HD 7790.
http://anandtech.com/bench/product/1126?vs=1044
here you go. That is how much difference there is.
