oh dear... I was about to break into my usual rant about how everything bottlenecks everything else to some extent... but ooooooh, that's gonna be a nightmare of a bottleneck. You really need to upgrade your platform if you want to run that 980 to any degree of good.
i5-4460/6500, H97/170 motherboard. Problem solved.
The CP will bottleneck pretty heavily.
I would suggest upgrading it to an i5 4460, 4690K or similar. Maybe even Skylake if your budget allows for it.
That 980 will be bottlenecked by the CPU. If you want to keep your motherboard, I would get at least an 8320. Or switch to Intel with an i5 4460/6400
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
Thank you :)
I got an Amd FX-4130 Quad-Core Processor running at 3.80 GHz. I have 8.00 GB of ram. A Ultra 500w PSU. I am planning to upgrade to a GTX 980 around Christmas time. Will I need to upgrade anything in order for the GPU to reach its full potential. Thank you.
amd fx 9590
amd fx 9590
Are you serious? He'll need a VERY stable motherboard, PLUS a good cooling system.
