best card for 3 1080p monitors ?
Go to solution Solved by Amazingasian,
R9 390
HI,
First of all I must say I don't have a great deal of money.
I'm looking for the best gpu solution (sli or single card)to run 3 monitor gaming at 1080p (22-27") I plan to start with three smaller monitors(21.5"-22") but wish to upgrade to 27" in the future without changing my system.
the games I want to play are(If supported):
Rust
Minecraft
The Forest
Stranded deep
Possible games I'd like to play(but not necessary):
GTA 5
Far-cry 4
The witcher 3
Mad Max
Thanks for your time :)
p.s I've spent a while looking for a solution but always get pointed to the gtx 980 which I don't have the money for
R9 390
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
HI,
Rust
Minecraft
The Forest
Stranded deep
GTA 5
Far-cry 4
The witcher 3
Mad Max
980 but since you can't afford try to get a 390X or 390
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
HI,
Rust
Minecraft
The Forest
Stranded deep
GTA 5
Far-cry 4
The witcher 3
Mad Max
definitely 390 not the 390x since the higher price really isn't justified by the features.
A mix between the red and the green team
390x. it does performs better than 390 i personally tested both of them and also the 970. 390x is toe to toe with 980 but cheaper. in battlefront it even performs better than 980 according to benchmark.
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
What haha?
Overclocked 390 vs 390x, 390x will win.
970 vs 390
980 vs 390x
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
What haha?
970 vs 390
980 vs 390x
That word 'overclocked'... on an AMD Card.. I don't think I need to say anything more
You are making false statements. Overclocking on an AMD card is fine, temps are fine, power usage is fine, and every MHZ does more on an AMD card compared to nVidia.
Hmmm, I Think i'll go for the R9 390
I have another graphics card i can get hold of for quite cheap, what are your opinions on the R9 270X ?(4gb msi edition )
HI,
Rust
Minecraft
The Forest
Stranded deep
GTA 5
Far-cry 4
The witcher 3
Mad Max
Are you looking to Max out 60 fps while gaming on all 3 screens? Like play a game on 3 screens? Or multi task and play on one?
CPU: Intel i7 8700k || Motherboard: Asus Z370-E ROG || RAMCorsair 4266 2x8gb || GPU: Sapphire r9 280x tri-x || Case: Corsair 780t ||
Storage: Samsung 850 Evo 250GB, 1TB Segate Barracuda HDD || PSUSeasonic M12II Evo 850w || Display: AOC i2367FH 1920x1080p 23 Inch ||
CPU Cooler: Corsair h80 || KeyboardCorsair Strafe || MouseCorsair Scimitar || HeadsetHyper X Cloud II || OS: Windows 10 ||
it doesnt matter what screen size you have
if your 21" monitor runs at 1920x1080.. it will use the same GPU power as 27" running at 1920x1080
Im looking for a bit of both ideally
If u wana play games on Max settings like witcher 3 with hairworks then a 980ti is good. 980 is cutting it close, it can't Max out games on 3 monitors. You'll need something the power of a 980ti for the future as well. A 980 won't cut it in the coming years if u want to Max out games
R9 390
Too weak for 3x1920 x1080 if for example he plays fps games on 3 screens.
a STOCK 980 is 5-10% faster then a STOCK 390X
a STOCK 390X is 10-15% faster then a STOCK 390
a STOCK 390 is 5-7% faster then a STOCK 970
a STOCK 980 is 15-20% faster then a STOCK 970
a 980 costs 500 USD
a 390X costs 400 USD
a 390 costs 300-320 USD
a 970 costs 190-320 USD
.... a 390X is 80-100 bucks more then a 390. gives 10-15% more performance.
No matter how much you OC, if a 1.2GHz 390 beats a 390X, then a 1.15GHz 390X will beat a 1.2GHz 390. Beacause it has MORE stream processors. It's like the argument that a 1.6GHz 970 will beat a 980. Sure, but a 1.3GHz 980 will still wipe the floor with that 1.6GHz 970.
It's within budget.  A 980+ would be best but it's too expensive.
You'd be looking at 50-55fps on one screen, 30-40 on 3
I can play games like rust and the forest etc. currently on two monitors with no problem and i only have a EVGA 660 2gb(discontinued)
