Will I 4K
Go to solution Solved by RobertElkHunter,
Very simmilar in performance to mine, and mine won't do 4K well at all. So I have to say no.
That said, it will power a 4K monitor just won't game well on it.
lol yeah
at low settings
https://linustechtips.com/topic/471961-will-i-4k/#findComment-6327646
Low FPS at Low settings.  It won't even max out 1080p.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/471961-will-i-4k/#findComment-6327657
link: http://ca.pcpartpicker.com/p/tGt6wP
will it run 4k?
4K what?
4K desktop and youtube? yes...
4K gaming? not even close unless you play games that came out prior to 2010.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/471961-will-i-4k/#findComment-6327773
