So a friend of mine contacts me saying that his friend needs a new custom PC soon.  He is running on a PC that's like 9 years old he says.  It uses a PCI creative labs sound card.  He is an audio hobbyist and uses a keyboard w/ a 1/4 inch input.  I don't know much about the audio end and was looking at sound cards for his new build.  Also, what area should I focus on, mebbe an SSD, 8GB of ram, an I3 no video card?  He will give me a list of the programs he uses.
Thanks
Steph
My PC: CPU: I7-2600K CPU Cooler: Cooler Master Evo, Mother Board: MSI Z77 Mpower, Ram: 4x4GB DDR3 1600MHz CL9 Corsair Vengeance (Black), Case: HAF 932, PSU: CM GX 650 (Upgrading to RM750 soon), SSD: Samsung 840 Pro 120GB SSD, HD:  750GB Seagate 7200 RPM, Optical: Samsung Blu-ray burner, GPU: MSI GTX 560 TI Twin Frozr (Upgrading to an HD R9-290X on launch)
https://linustechtips.com/topic/46792-i-need-a-lil-help/
Hows this PCPartPicker part list / Price breakdown by merchant / Benchmarks
Motherboard:  ASRock 960GM/U3S3 FX Micro ATX AM3+ Motherboard  ($54.99 @ Amazon)
Memory:  Mushkin Redline 8GB (2 x 4GB) DDR3-1600 Memory  ($84.99 @ Newegg)
Case:  Apex PCV-588 (Black) ATX Mid Tower Case  ($44.98 @ Outlet PC)
Total: $413.05
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-08-16 20:07 EDT-0400)
Cheap good maybe add more space or switch to ssd
Edit: also add a Sound card
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-618761
Well, any ASUS xonar sound card would do well. Maybe go with an AMD APU based system if not rendering.
Edit just saw youbetternot's post:
I have this HDD: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=744346&csid=_61 $49.99 AR 200MB/s easy.
That memory seems a bit pricey as well, you can get a 16GB kit on sale for that price.
Wouldn't sink money into a phenom build at this point.
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-618764
an audio enthusiast that uses a keyboard audio input... interesting.
if he wants something external of the case to plug into there is the creative zxr with the external audio plug ins and volume knob
of course the fiio e10 or plenty of other external dacs that he could use to have an external audio plug
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-618782
I was looking at this: http://pcpartpicker.com/p/1sNPa
But he's probably coming from a single core pentium, so I am not sure what power he needs.  But I'll get more info Sunday, but I doubt he needs some serious power, but he might so it might be a higher tier setup even!!
Thanks
Steph
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-618942
Budget? Does he need peripherals? Copy of Windows?
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-618958
I assume he's talking about an electric piano not a typing keyboard.
if he's recording he should look for an external audio interface, not a sound card.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619048
Okay so he's like to stay under 500, I have windows so that's no issue.  This is what I came up with: http://pcpartpicker.com/p/1sQ4x.  This way if he wants a graphics card we can add one down the road no issue.  But he doesn't care for video editing.  I would consider an APU, but I haven't used one before so I am still a lil skeptical about things like heat and such.
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619428
That's how he's doing his recording and such now.  So I went with a decent Asus Zonar card.
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619433
Or I might do this: http://pcpartpicker.com/p/1sQae
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619486
if he's recording on an external interface now why get a sound card at all?
or does the interface only have input?
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619582
He is recording using a sound card right now, a PCI sound card that is.  I'll learn more Sunday.
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619598
If the soundcard he's using has drivers for Windows 7 or later then he can probably keep using the one he's got.  I mean, sound technology doesn't really go obsolete like other technologies do.
If the soundcard is as old as the computer, though, I'm doubtful it'll have those drivers...
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619754
Is there a huge difference between these 3?  Also the boards I am looking at don't have PCI slots.
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132052
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132013
The differences I know of is the first 2 are 5.1 audio and the last one is 7.1 audio.  But then there's 24 bit sound @ 96KHz vs 192Khz and tbh I know absolutely nothing about this part :(.  This is the board I am eyeing up atm: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157334
Thanks
Steph
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619853
Actually if I get a sound card I'm gonna get this board: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130708
:wub: MSI boards :)
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-619892
I can totally see where you're coming from, but like neither him nor I probably know exactly what he would need based on what he does.  He's doing everything from a sound card and we'll probably keep it that way tho, less confusing\
Thanks
Steph
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-621878
He hasn't given me a list of the programs but he said he'd like to get back into audio/midi sequencing whatever that is :(, time for google!!!!
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-623080
So... you need a recording interface.  :lol:
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-623507
Sounds to me like he needs a copy of reaper (free version out there), a usb midi interface and an external soundcard with the lowest latency you can find.  I have had no problems with the SoundBlaster digital live range (almost identical to what t0wer linked you to). I can multi track and do not have to edit for synch issues.
Don't waste your time with an internal soundcard,  they might be o.k for recording one shots, but as soon as you try to layer a second track there is a good chance you'll get issues.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-623621
Well the thing is, he's used a sound card for 6 years doing his work and I mean he knows better than I do what he needs.  So mebbe just a 5 channel sound card?
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-623731
Get him to sign up and ask,  we love talking about  this stuff. Then we can also get a first hand idea of what he wants/needs.
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-623794
He's not a techie, He works 70-80 hours a week and barely has time to do music stuff on the side.
https://linustechtips.com/topic/46792-i-need-a-lil-help/#findComment-623956
