Hello VIPs (very intelligent persons),
I'm here to ask a simple question: I know the heat dissipation value of a radiator and the heat output of my system, so how can I calculate the temps of the components? Can I also calculate the temperature of the water?
Thank you for your time,
EMENCII
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/467674-temps-rads-maths/
You can view the temperatures using programs like Aida64, CPUZ, Realtemp, etc.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274491
EMENCII
 Software can tell you temps of hardware.  Water temps nobody has bothered though.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274493
It's to plan how much rad space I want, I dont have the system ^^'
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274506
Water temps rarely matter unless you live in a volcano.  1-4c water temp difference won't make any real difference to your hardware really.
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274520
Different components will output different amounts of heat.  It's rather hard to calculate since every part is unique.  For example, one CPU could idle at 33*C but another one of the same model with the same cooler could idle at 29*C.
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274524
its hard
where do you live ?
do you put the Computer on a AC room ?
what compoment you gonna watercool ?
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274525
I was thinking about load temps, I know the output is different but was just to plan, not to create a nuclear reactor, just more or less...
its hard
where do you live ?
Both CPU and GPU, but I wanted to use the AC's rad to cool the components, that's why I was asking, found very little material about this. I live in Italy, is written under my profile pic ^^
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274547
EMENCII
You can never calculate the component or water temperature but you can read them from various different software like Aida64 as mentioned by the others. To measure/read the water temperature from the reservoir with parts like this or this and there are others as well but do the same thing.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274577
120 will do at Push Pull config but if planning to leave the AC room get 240mm
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274579
there are too many variables to calculate the temperatures that you will get
surface area, air speed, air temperature, energy transfer, block efficiency, etc...
its just not possible without a computer simulation
the simple rule is at least one 120mm rad per component, and if youre not limited by budget just buy as much radiator capacity as possible
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274598
i'd want to extend the above formula:
if stock voltage/clocks then a 120mm per cooled device.
if overclocking with more voltage, then a 240 for CPU and 120 for each GPU.
i think @JayzTwoCents uses a 240 per overclocked device formula.
as to coolant, that really cannot be nailed down due to too many variables.
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274721
"use the AC's rad" I meant connecting it with tubes at the loop, not talking about 120mm and stuff, it's 800*450mm... 4.5KW of heat dissipation... So maybe I could put two... :D
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274834
you still cant calculate the temperatures exactly
just build the loop and use temperature sensors to get the values
that rad is definitely enough for any system
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274913
I know, but knowing in advance is always good ^^
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6274986
I know, but knowing in advantage is always good ^^
you mean advance, not advantage, right?
:P
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6275068
:P
Sorry, not really awake right now ^^'
https://linustechtips.com/topic/467674-temps-rads-maths/#findComment-6275085
