So I overclocked my i7 4790k to 5.2 at 1.4v
Temps are 70c at full load stress testing
So temps are fine, is it ok to have high voltage if temps are good or does voltage effect other things that are bad for the cpu ???
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/467498-voltage-and-temps/
As long as temps are fine and you're not scared about VRM cooling or powering it...you should be fine.
That's one awesome overclock.
Sig under construction.
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6272018
Holy shit that's a pretty nice overclock. If it's only 70 under full load you're fine (Be sure to stresstest really long) Higher voltages will wear down the CPU faster but I bet you already know that
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6272021
Should be fine, well arent you lucky
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6272022
I've heard that 1.35v is the highest you should go for Haswell refresh chips, anything higher speeds up deterioration (Don't take my word for it) but really nice overclock....
Has anyone killed a chip from to much voltage with ok temps yet ??
Iv not heard of anyone
also (1600)
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6272062
Yes, it doesn't matter about the temps if the voltage is not stable or can't go anymore the chips lifespan is effected or the chip gives out.
ok cheers, think il drop back to 4.8 at 1.28v
also (1600)
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6272068
OP if you don't break 80c its fine, dont listen to le nooberinos.
Don't do any folding or anything like that.
I would see what it'll take for 5Ghz and leave it at that, nice chip btw.
PEWDIEPIE DONT CROSS THAT BRIDGE
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6272120
It takes alot of voltage to actually kill a processor.
At least 1.8V is required to kill it if you fancy being really silly without using extreme cooling methods.
Is is 5GHz on all cores? 70C load is great as well. Good job.
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6274221
5.2 on all cores dude :) I used some of that coollab liquid stuff instead of thermal paste it's really good
also (1600)
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6274259
Sounds like your chip is similar to mine :D
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6274269
1.4V on Haswell is overvolting very hard. - 1.35 is the safest I'd dare go. If you can get 4.8 on 1.28V then you just won the silicon jackpot
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6274273
Oh yeah 5.2GHz @1.4V is great. Personally i'd just keep it there or at 5GHz at least. Your cooler is definitely up to the job at keeping it happy.
coollab liquid metal is great 'paste'. It's definitely helping the temps stay low.
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6274304
id recommend it for ur next paste dude it's well good, at stock speeds my temps are 35 at load and 14 idle ( which is my room temp lol)
also (1600)
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6274316
Let me ask you this. Is it 5.2ghz across ALL CORES?
Main Rig
Plex Server WIP
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6274328
ye it is
also (1600)
https://linustechtips.com/topic/467498-voltage-and-temps/#findComment-6274329
