So I've been having a sound issue, contacted gigabyte they didn't know, they suggested testing outside the case so I did it a couple mins ago ran it and to my surprise the sound was gone ! But I wanted to load into windows to make sure so I plug in my keyboard and as soon as I plug the usb plug into the mobo the sound starts again :/..... so I tried every usb slot and the sound still continues, when I unplug the keyboard the sound stops, when I plug it in it starts, I have no idea what to do ? My keyboard is a k70 so its not a cheap thing and I really need this solved so any help would be great
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/464335-found-the-problem-but-how-to-fix/
You might want to try using the front panel USB header connected to your case, or maybe invest in a pci-e usb card. Sounds like it could be electrical interference bordering on a short or something.
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
What sound, coming from where?
sound issue... for audio... it's a buzzing noise that's in the background no matter what volume
and a car thread !
but why wouldn't it happen for the mouse ? And front panel isn't an option, the pc is on my desk and it won't reach and it would look horrible
and a car thread !
Are you using Realtek? Make sure your phone is not close to the speaker. took me a week to figure that out...
yes I am, and again it has nothing to do with my phone it is my keyboard.....
and a car thread !
If you know the problem, why ask? I have a similar Motherboard and went through the same exact problem which is why I offered the help. I was placing my phone on the speaker while I used my computer. You also need Realtek downloaded off of Gigabytes website. There you can set the priority of the input. Make sure you don't have multiple channels at once. Say your headset and the speakers. This can create feedback.
If anyone asks you never saw me.
umm maybe I asked the question because I need a solution maybe ? And I stated the problem in the first post, I've already downloaded the latest driver from gigabytes website
and a car thread !
Try different keyboard.
don't have another keyboard, I have the only desktop in the house so there's only a need for one keyboard :/
and a car thread !
And as such I offered one possibility. Good luck in your search for an answer.
Well then go out and buy a cheap usb keyboard like from Logitech. Try that out. If sound disappears then it's your K70. RMA your K70 for a replacement.
Keep the cheap keyboard on the side for backup use, when you need it.
how was telling me that my phone could be causing it an answer ? I already said it was my keyboard....
and a car thread !
Ya I might have to do that :/ I'll just buy a cheap one and return it, I don't have any good tech shops around so tge cheapest this will probably be 50$
and a car thread !
no ones going to want to help you if you're being slightly douchy about advice they try to give you bruv
cpu:i7-4770k    gpu: msi reference r9 290x  liquid cooled with h55 and hg10 a1     motherboard:z97x gaming 5   ram:gskill sniper 8 gb
OK, lets do this. Because you could be wrong. Happens to me all the time. It could be your keyboard, but if you were placing your phone on the speaker and not even thinking of it when diagnosing the problem, I saved you buying a keyboard. That's me the dick, trying to help.
I'm trying not to be douchy but if I already know the problem and stated it to home twice and he keeps going there's not much I can do
and a car thread !
first of all its headphones, second my phone is across the room, third if it was my phone why would it only happen when I plug In my keyboard ? Not trying to be a dick or saying your a dick but I told you what the problem was
and a car thread !
Because I'm not there. I have no idea your set up, whats happening when your having the problem, or anything else needed to be exact. If I hadn't JUST had this issue I would have sailed on by, but I did. I would have told someone they were crazy that it was my phone until I realized it was. Certainty is the best way to have an unsolved problem.
I know I should have specified that my phone wasn't anywhere near my pc but again I stated many times that it only happened when I plugged in my keyboard and when I unplugged it it was fine, that's some pretty good evidence saying it's the keyboard, sorry to have come across as a dick
and a car thread !
If I am not mistaken, your keyboard has two SUB  connectors. Are you suing both of them? Does anything change between using only one or both at the same time? There is also a switch for I believe BIOS compatibility. Try playing with that and of course when you flip it between the numbers 1-4 unplug and plug back in your keyboard. It's a long shot, but that it doesn't hurt to try.
If nothing helps, try contacting Corsair instead of buying a new keyboard. Explain the problem to them and discuss a potential RMA.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
yes it does have 2 plugs but one is simply a pass through plug for a port on the keyboard which I have my mouse plugged into, the noise only appears when I plug in the the for the keyboard itself, the pass through port is fine and has no affect on it, I have narrowed the problem further to the back light on the keyboard, when the back light is off the noise is gone, when it's on the noise appears and gets louder as the back light gets brighter, I'll try the bios switch and let you know
edit: bios switch didnt do anything :/ on to contacting corsair
and a car thread !
Definitely do that. Apparently there is some problem with the back light. I'm sure they will be able to help you out. :)
