Problems if I change components? - Win 10
Solved by exhaustedbrit,
Hey there buddy.
If you are running Windows 8 or above without a legacy BIOS, the installation should detect a chipset change and reinitialize your driver stacks. Otherwise you will get blue screens loading into windows because the Z97 platforms use a different chipset to the AM3+ platform. Other than that, you should not encounter any issues but I would double check RAM compatibility with the board you choose to buy. Though nowadays memory controllers are nowhere near as picky as they were some 15 years back.
