Can i get little more speed?
B@ttery
So i have 50 mb/s LTE connection with no data plan. Now it is connected trough RJ45 cable to my PC. So is there any way how i can get more speed? I have now only motherboard internal switch on use. Could i need maybe faster wi-fi adapter or something?
Failure is not an option!
you cant get anything faster than a cable...
That what i imagined also. Does i noticed if my next motherboard is 10/100/1000? Now i have 10/100 in my motherboard.
No you have a 50mbps connection and your ethernet is capable of 100mbps so your not saturating it.
o'h thank's! Have to ask, even i feel my self pretty stupid now. :D
Why do you want faster anyway? 50mbps is still pretty decent.
Well since it is an lte connection, the max data speeds are near 50mbps, so no.
My native language is C++
