For a smooth medium gameplay 60fps gtx 750ti or 960?
veltix
Whcih one is for a smooth gameplay at medium setting at 60fps? 750ti or 960?
Games i playing: cod ghost, aw, bf3,4 & hardline, metro last light , tomb raider and crysis3.
Specs are: i5 650 3.2ghz, prebuild 300w from hp.
R9-380 >960 > 750 Ti
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
960 is the obvious choice here as it is a lot more powerful than a 750ti. The 300w psu should be able to handle it. But if you spend some extra, a 380 has even better performance.
with my 750 Ti i can play Tomb Raider maxed out TressFX off and get a average of 50FPS
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
R9 380 + a PSU that won't fry any GPU attached to it
Get a better gpu and get a 380.
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
With that PSU, 750 Ti.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
So in other words, i need to get better psu and a 380 or gtx 960?
Ah, if you do get a better PSU. Get the 380. The 960 is a little disappointing.
What is the 380 recommendations for the power how many watts?
A good 500w psu will be nice. I recommend units from SeaSonic or SuperFlower.
Im using hd 7770 sapphire for 2 yrs under 300w. Seems no problem,till monitor turn no signal? Gpu dusty? or burn? Is 7770 = 750ti?
That is a very low power GPU. The 380 uses quite abit more. If you do not get a PSU that will handle this component, you might end up destroying one or more of your components.
If you don't want to get a new PSU then your only real option is one of the 750 Ti's that don't need external power. If you get a new PSU from a good brand in the 500w range you can power either the 960 or the 380. Both will do what you're asking with the 960 consuming less power. If you plan on getting the 380 do not get a CX430 as it does not have enough PCIe connectors for the card.
"The of and to a in is I that it for you was with on as have but be they"
Еrm 380 and 960 have the same connectors and draw almost exactly the same amount of power.
Really? because every 380 I've seen is either x2 6pin or a 6pin+8pin whereas there are several single 6pin or 8pin 960's. Even my SSC 960's only have a single 8pin.
*Correction, just saw that the strix 380 has a single 8pin. My point still stands though.
Most 960s I've seen come with 2x6-pin and I've not seen a 380 with a 6+8-pin - even the Sapphire Nitro and MSI cards - the ones geared towards OCing - have 6+6-pin
Have you considered getting a GTX 950? it's really close in performance to the GTX 960.
**MID POST EDIT**
Well shit
After typing up all of the 960's I went to list the 380's only to find that TPU listed the Strix 380's as a 6+6 card when I know it isn't because I'm looking at a picture of one right now. So I went through the 380's and found pictures to confirm the pin layout on all of the 380's. I didn't do the same for the 960's due to the sheer volume of 960's out there and the fact that a large majority of the 6 pin versions are reference cards which are ALL 6pin.
Right so because I misremembered various power connectors on cards I decided to go find out the which cards have what connector types, I used Techpowerups GPU database for this. I tired to remove ones that just featured different I/O layouts but some might have slipped through.
GTX 960
8+8pin:
Colorful iGame GTX 960 Flame Wars X
6+8pin:
Gigabyte GTX 960 Windforce 2x 4GB
Gigabyte GTX 960 Windforce 2X OC 4GB
Zotac GTX 960 Extreme OC
Zotac GTX 960 Extreme OC TOP
6+6pin:
Galax GTX 960 SOC
Gigabyte GTX 960 G1 Gaming
Gigabyte GTX 960 Windforce 2x OC
Gigabyte GTX 960 G1 Gaming 4GB
Inno3D iChill GTX 960 HerculeZ X3 Air Boss Ultra
8pin:
Asus GTX 960 DirectCU II Black
Asus GTX 960 DirectCU II Black OC
EVGA GTX 960 FTW ACX 2.0+
EVGA GTX 960 FTW ACX 2.0+ 4GB
MSI GTX 960 Gaming LE 100ME
MSI GTX 960 Gaming MGSV
Zotac GTX 960 AMP! Edition 4GB
Zotac GTX 960 4GB
MSI GTX 960 Gaming
EVGA GTX 960 SuperSC ACX 2.0+ 4GB
MSI GTX 960 Gaming 4GB
MSI GTX 960 Gaming 100ME
Galax GTX 960 EXOC White
KFA2 GTX 960 EXOC
Galax GTX 960 EXOC
EVGA GTX 960 ACX 2.0+ 4GB
6pin:
Asus GTX 960 DirectCU II OC
Asus GTX 960 DirectCU III OC
Asus GTX 960 Mini OC
EVGa GTX 960 ACX 2.0+
Gainward GTX 960 Phantom
Gigabyte GTX 960 IX OC
MSI GTX 960 OC
Palit GTX 960 Jetstream
PNT XLR8 GTX 960 Performance Edition
Zotac GTX 960 (dual fan/single fan)
Zotac GTX 960 Galactic Edition
Point of View GTX 960
Point of View GTX 960 AMMO
Palit GTX 960 Jetstream 4GB
Palit GTX 960 Super Jetstream
Palit GTX 960
MSI GTX 960 OCV1
Leadtek Winfast GTX 960 Hurricane
MSI GTX 960
Gigabyte GTX 960 Windforce 2X CN
KFA2 GTX 960
KFA2 GTX 960 OC
Inno3d GTX 960 HerculeZ 2X OC
Inno3d GTX 960 HerculeZ 2X OC 4GB
Inno3d GTX 960 HerculeZ 1X
Gigabyte GTX 960 OC
Gigabyte GTX 960 OC 4GB
Gainward GTX 960 Phantom GLH
Galax GTX 960 OC
Galax GTX 960
Gainward GTX 960 Phantom 4GB
EVGA GTX 960 Superclocked
Gainward GTX 960 OC
Asus Turbo GTX 960 OC
ELSA GTX 960 S.A.C SS
ELSA GTX 960 S.A.C
Colorful iGame GTX 960 Flamewars U
Biostar GTX 960
Colorful iGame GTX 960 BURI-Mini
Asus Strix GTX 960 DirectCU II OC SP
Asus Strix GTX 960 DirectCU II OC 4GB
R9 380 (corrected used pictures to confirm pin layout)
6+6pin:
Club 3D R9 380 Royal Queen OC 4GB
Gigabyte R9 380 Windforce 2X OC
HIS R9 380 IceQ x2 OC
MSI R9 380 Gaming 4GB
Sapphire Dual-X R9 380 OC
Sapphire Nitro R9 380 4GB
MSI R9 380 OC
Powercolor PCS+ R9 380 4GB
HIS R9 380 IceQ X2 OC 4GB
MSI R9 380 Gaming
XFX R9 380 Double Dissipation 4GB
XFX R9 380 Double Dissipation Black Edition
8pin:
Gigabyte R9 380 G1 Gaming 4GB
Sapphire R9 380 ITX Compact
Asus Strix R9 380 DirectCU II
Asus Strix R9 380 DirectCU II 4GB
Asus Strix R9 380 DirectCU II 4GB OC
@don_svetlio
@Ostwind - nice list - I actually didn't know there was a 8+8 960 - talk about OC potential :D
But yeah - the power draw on these cards vary from OEM to OEM and from factory OC to factor OC and voltages but for the most part they are within arm's reach of each other
@@Hiebly
Are all hp pc cpu sealed. Cannot change from i5 650 to i7 920? And also what gpu can i7 920 handle if change psu.
@Hiebly
A psu of 300w and i5 650 able to support: (1) r7 250x (Y/N) (2)gtx 750ti (Y/N) (3) r7 360 (y/n) 4) r7 260x (Y/N)?
Will it bottleneck the games or lagging. Will be running on med/high no aa. Achievable to 60fps or lesser than that?
Games are: mgsvpp,bf3,4,hardline. Mw3,aw,ghost and bo2. Crysis3 and ac unity.
