hello there, as the tittle says i'd like some advice for the pc am planning to build(first time) so far it contains
case:corsair vengeance c70
motherboard:msi z97 gaming 5
cpu:i5 4690k
ram: corsair vengeance pro 16gb
GPU:msi geforce gtx670 gaming 4g
what type of a cpu cooler should i get air or water? do those sealed cpu coolers need some sort of a waterblock or not?
also what psu should i get since i can't calculate the watts correctly
thanks in advance:)
post-265159-0-56014900-1443386078_thumb.
https://linustechtips.com/topic/457365-advice-for-pc-build/
A SeaSonic S12G or G-series 550W is enough
EVGA G2/GS 550W
Super Flower Golden Green/Leadex 550W
Antec High Current Gamer 550W
Any of those
for CPU cooler - 212 Evo
You don't need 16GB of RAM
Get a R9 380 4G - it's better than the 670
do you have a 670 or 970 planned?
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137520
cpu:i5 4690k
thanks in advance:)
Location, total budget? Use pcpartpicker.com if it has your country.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137524
cpu:i5 4690k
thanks in advance:)
Welcome to the Forum.
I'd recommend going for a Noctua NH-D15 over the Cooler Master V8 if you want to spend the money on a good CPU cooler and are okay with the color scheme.
Also, I'd go for a good 500w PSU (so stay away from no-name brands and don't get a Corsair CX). I'd recommend an EVGA PSU of some sort, let's see if I can find a nice one.
Sig under construction.
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137525
I would recommend a a Crucial MX200 SSD and WD black hard drive.
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137527
thank you all on your quick answers
EVGA G2/GS 550W
Any of those
sorry meant 970 just typo
 would a 500-550w psu cover everything? including extra fans,ssd,hdd
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137638
550W is enough - but be careful what PSU you get. Stay away from cheap crap like Diablotek or the Corsair CX/CS/VS
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137653
PCPartPicker.com provides a good estimate of power requirements for a build.
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137677
thanks one more thing is 16 gb ram to much ?also should i switch out the corsair vengeance  for kingston hyperx?
thanks m8
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137771
thanks m8
Get the cheapest ram available. It makes 0 difference. Also 16GB is more than you will need yes. Is it too much? I don't know. If you can buy better parts elsewhere by downgrading to 8GB then do so. If not 16GB is fine.
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6137961
Not accurate. There is a difference in memory parts. A measurable difference. Even in games, although it is very small.
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6139658
Not true.
There is not a statistically significant measurable difference above a certain speed/timing (for ddr4 that seems to be 2400, for ddr3 its pretty accepted to be 1600).
http://www.anandtech.com/show/8959/ddr4-haswell-e-scaling-review-2133-to-3200-with-gskill-corsair-adata-and-crucial/6
Note that their 95% confidence interval is +/- 2 fps so literally there is no statistically significant difference.
Same with DDR3 above 1600.
http://www.anandtech.com/show/7364/memory-scaling-on-haswell/7
LITERALLY they have ONE test that has any statistically significant differences (that is dirt 3 min fps) and it's all over the place. There is ZERO difference for gaming (with discrete graphics).
https://linustechtips.com/topic/457365-advice-for-pc-build/#findComment-6139687
