100ft Ethernet cord (HELP)
Hi guys i recently finished my computer and need your help now for getting a way to hook my pc up from the other side of my house.
so i have a question
since im running my cord from my 2nd level of the house to the first I have to run the cord outside
1. I found our that cords for outside Ethernet are expensive cant i just duct tape it with uv water resistant tape ?
2. How do I get it out of my window without making a hole and still be able to close the window (seal it )
3. I have to hide the cord so do i paint it the same color or attempt to line it under the siding
4. does the length of a cord affect the speed
so do i get this and tape it http://www.homedepot.com/p/Leviton-100-ft-White-Cat-5e-Patch-Cord-R40-AG500-00W/202077707
or do i get this and do it myself
Don't worry about an "outdoor" spcefic cable. A regular cable should be fine with water and the sun might break the jacketing down eventually but you're not doing mission critical stuff anyways.
If you go to home depot and buy some of their styrofoam http://www.homedepot.com/p/R-Tech-2-in-x-4-ft-x-8-ft-R-7-7-Rigid-Foam-Insulation-310891/202532856, you can do something like this to get the cable out of your window:
Brown is the sliding window itself, black is the frame, pink is styrofoam, gray is some duct tape. You basically make it so the window doesn't close all the way but you use the styrofoam to "extend" it with something you can then drill a hole through and run yoru cable through. If you don't have sliding windows this plan won't work obviously. It's very similar to how window mounted air conditioners are installed.
