Best UltraWide Monitor?
Beeeyeee
Hello guys! in your experience, whats the best Ultrawide monitor?
I just have a few requirements.
  • Vesa Mount
  • Height adjustable stand
  • curved
budget?
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
budget?
I really don't have one, If its worth the premium i'll save up a bit more and get one.
If you are ok with 60hz then the U3415W, 34UC87 and the SE970C are all good
The Acer Predator X34 is coming out which is G-Sync and overclockable to 100hz
May I ask why you need a Vesa mount and a height adjustable stand? Surely if you wanted a vesa mount then you would not care what stand comes with the monitor
because eventually I will get a Vesa arm, but for now I just need the monitor, I'm also planning on getting another 27" 16:9 4k Monitor for recording Videos
All the ones I suggested have height adjust and vesa. The dell has the best stand imo but it's more subjective - which ever you think looks nicer.
DELL U3415W. I'm using it now.
The stand is one of the best out there. And you can put your monitor at very low height with the stand.
