Anti static strap + electrical tape
Solved by W-L,
I have an antic static strap, but it instead of an alligator clip, it has a proprietary plug at the end, its made of metal at least.
What I am wondering is if I were to just tape this end to my PSU (plugged in and turned off) would I be safe?
Is electrical tape the right kind to do this with? Or should I use scotch tape?
Yes that will work just make sure the paint isn't preventing a good electrical contact and you won't have any problems.
