Hey, I was wondering if getting a lower TDP CPU is better for building a silent PC. Lower TDP means less heat = less rpm = less noise. But how much differences does it make?
I'm looking at the new i7-6700 (65W) and i7-6700T (35W). The 6700T is less powerful than the 6700 and costs about the same, so if you're comparing price to performance it's a bad deal. But I'm more interested in noise.
https://linustechtips.com/topic/444483-tdp-and-noise/
You can simply get a cooler that can allow the fan(s) to run at lower RPMs. Also another factor in noise is the quality of the fans themselves. If the fans are terrible, you may get more noise from the bearings.
https://linustechtips.com/topic/444483-tdp-and-noise/#findComment-5956795
Don't worry about getting a CPU with more heatoutput. Just counter that by getting a bigger CPU cooler. the bequiet Dark Rock 3 (or even the Pro version) is a very good CPU cooler for silent air cooling. It is amssive and will distribute the heat onto a big surface are so you can tune down the fans and ahve them run very quiet.
who cares...
https://linustechtips.com/topic/444483-tdp-and-noise/#findComment-5956808
its not the TDP that decides how much noise you get, its how efficiently you can get rid of that TDP into the air.
i have a 4790K, and i literally dont hear it over the highway thats almost half a mile away from me, with a forest in between.
https://linustechtips.com/topic/444483-tdp-and-noise/#findComment-5956809
It depends on the cooler - my Freezer runs @ 1500 RPM - CPU is bellow 50*C at max load and I cannot hear it unless case is open and I am under the desk
https://linustechtips.com/topic/444483-tdp-and-noise/#findComment-5956811
You might get away with the 65W tdp version, however it is more important what cooler you will be using. I am currently on a G3258, which has a 54W tdp and the noctua nh l12 92mm fan is on its own doing a great job, since the max. power it is using usually is inbetween 20-35W. my next purchase will most likely be a 2.0Ghz xeon, so that I probably will get away with an all passive cpu heatsink. Also I want to mention, without being biased, go for be quiet fans if you really want dead silence in your case. I simply know from experince what is best, because I really like when things are quiet when I am working at my computer :P
If one does not fail at times, then one has not challenged himself.
https://linustechtips.com/topic/444483-tdp-and-noise/#findComment-5956829
Lower TDP means that your fans don't have to do as much, this is true. I think if you put an NH-D15 on a Celeron you probably wouldn't even need a fan.
That said, I would sooner upgrade the cooler than use a low power CPU to solve this problem if this is at all an option.
https://linustechtips.com/topic/444483-tdp-and-noise/#findComment-5956910
u can even have a high tdp cpu and a beefy cooler like mine and you don't here it even at full load.
don't save on the cooler.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/444483-tdp-and-noise/#findComment-5956985
Guest
