I'm planning a build with a budget of $500-600 entirely for gaming. I have no particular games in mind for this build.
AMD FX-6300 3.5GHz 6-Core Processor
Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard
Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Sapphire Radeon R9 270X 4GB Dual-X Video Card
NZXT Phantom 410 (White) ATX Mid Tower Case
EVGA 500W 80+ Bronze Certified ATX Power Supply
Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
What are your thoughts on this build? What could I change/improve?
https://linustechtips.com/topic/444248-500-600-gaming-build-help/
check out all my lists, and choose one you like.https://pcpartpicker.com/user/Nerd4L1F3/saved/#view=PNpkcf
The Fx-6300 is only as great as they say once you OC it. I would rather see you rocking the A10-kaveri APU than the FX.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($102.99 @ SuperBiiz)
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard  ($79.99 @ Newegg)
Video Card: Sapphire Radeon R9 270X 2GB Dual-X Video Card  ($179.99 @ B&H)
Case: Apex Vortex 3620 ATX Mid Tower Case  ($33.30 @ SuperBiiz)
Total: $586.18
Generated by PCPartPicker 2015-09-04 23:08 EDT-0400
http://pcpartpicker.com/p/wdhLRB
Here you go, doesn't look as good (IMO) but it'll perform much better. I think this PC will do you well, and you can also upgrade the case and such to make it look better down the road.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
edit:
or you could get a 280x for the gpu instead
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($166.95 @ SuperBiiz)
Motherboard: MSI B85M-E45 Micro ATX LGA1150 Motherboard  ($56.70 @ SuperBiiz)
Memory: Team Dark 8GB (2 x 4GB) DDR3-1600 Memory  ($34.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.20 @ SuperBiiz)
Video Card: MSI Radeon R9 380 2GB Video Card  ($189.98 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($39.60 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($59.40 @ SuperBiiz)
Total: $590.82
Generated by PCPartPicker 2015-09-04 23:14 EDT-0400
BigDay
Total: $590.82
Best build you could find.
Xeon 1231 v3/ H81m - P33 / 8GB Corsair Vengeance/ GTX 950/ Fractal Design Core 1000.
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($61.20 @ SuperBiiz)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($229.98 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($54.00 @ SuperBiiz)
Total: $572.25
Generated by PCPartPicker 2015-09-04 23:22 EDT-0400
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
edit:
Total: $590.82
Do you build houses?
Because Damn you nailed it.
280X is better though, unless temps are a factor.
edit:
Total: $590.82
Pretty much this.
I think I would go ahead and get an H97 board, just so there is no chance of compatibility issues.
maybe change the ram, just so you can get all parts from the same place. i see everything is from superbiiz cept the memory.
if you have the ability to do so... you could Scrapyard a $200 Graphics Card from your local area, if possible. to maximize FPS.
mmhmm
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($90.00 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler  ($23.40 @ SuperBiiz)
Motherboard: ASRock 970M PRO3 Micro ATX AM3+/AM3 Motherboard  ($57.60 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($50.40 @ SuperBiiz)
Total: $529.17
Generated by PCPartPicker 2015-09-05 06:01 EDT-0400
try this instead
Total: $586.18
Total: $572.25
i3 is a downgrade... But the i3 has upgrade options indeed... (anything below i5 from Intel is kinda not worth it...)
I think you should add a R9 380! :) (unless it cost to much...)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($54.00 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($42.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card  ($172.98 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case  ($37.99 @ Micro Center)
Total: $583.80
Generated by PCPartPicker 2015-09-05 07:00 EDT-0400
The site has changed....
honestly with a gpu like the 280x there wont be much difference between i3 vs i5, i have some beencmarks if you want top see
http://www.techspot.com/review/972-intel-core-i3-vs-i5-vs-i7/page5.html
consider the gtx 960 benches not the 980 because its closer to a 280x. you can see there that the difference between the i3 vs i5 isn't that big.
Rigs I've Built
That depends on the game... (Benchmarks maybe not but in game well...) :P
the resource i provided were games, but here are some more
http://techbuyersguru.com/best-gaming-cpus-pentium-vs-core-i3-vs-core-i5-vs-core-i7?page=2
in this resource the only game to take a large hit is crysis 3, but its still showing that in majority of games the i3 can keep up.
Rigs I've Built
I would pick FX-6300 over i3 any day, its not that it does not work its just that the FX is a better pick. If I had to upgrade later then I would gotten the Pentium and upgraded to i5 later... :P (but Pentium is terrible!)
http://www.hardwarepal.com/best-cpu-gaming-9-processors-8-games-tested/
the fx 6300 has HORRIBLE FPS DROP in minimums. the i3 would be the better choice
Rigs I've Built
lol sure...
Oh and the FX-6300 can be OCed...
lol sure...
-snip-
adding to the cost with a aftermarket cooler
and ofcourse you would choose benchmarks where the fx 6300 is overclocked
look on this fourm
http://linustechtips.com/main/topic/401217-amd-fx-vs-intel-for-gaming-2015-edition/
in terms of minimum fps, the i3 beats even the 9590 in some cases
Rigs I've Built
look on this fourm
And they have no video proof?
benchmarks are the same thing.
if you say "the can be faked" your videos can be too cause of the fps just being in the top right corner.
Rigs I've Built
Sorry I do not trust those benchmarks anymore cause they do not match reality... :(
quite funny you say that, how the i3 can beat the 6300 in quite a few benchmarks...
