Best CPU for R9 380?
Solved by BobaBalls,
I'm helping my friend to build a PC. We have decided that the best GPU for him is the AMD R9 380. That is not changing. He needs a CPU (preferably intel because he loves mass effect and DayZ) that will not bottleneck the R9 380, but also one that will not break the bank unnecessarily.
What do you guys recommend? I was thinking 4th gen i5 but I think something like the 4690k is overkill. Ideas?
i have a 280X and an i5 4460, no bottle neck, and it runs smooth. (upscaled my 1080p monitor to 1440p using the GPU)
