If you want better audio quality, yes.
https://linustechtips.com/topic/440748-hd-audio/#findComment-5907603
yes if you want to use your front panel audio jacks
https://linustechtips.com/topic/440748-hd-audio/#findComment-5907661
Yeah, If you want to plug your headphones on the front panel audio jack.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/440748-hd-audio/#findComment-5907717
