AVERMEDIA Broadcaster HD Capture Device 50 bucks
SirNumbers
http://www.amazon.com/gp/product/B00H2T65VU/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00H2T65VU&linkCode=as2&tag=o001b-20&linkId=Z7SYJBV655SUFNHO
  • Gameplay live streaming and capture HD content up to 1080p (VESA resolution support)
  • Record on-screen activities of another PC, real-time HD H.264 recording
  • Auto-resolution detection and support 3D video source playback
  • Compliant with Adobe Flash Media Live, Xsplit, and wirecast
@Tocsin_786 has one he might want to comment
Fedex Ground must be on Horse back, It took 7 days to go 200 miles
Does it have 720p60 capability? Hate to ask here :)
Looks like a really good deal.
most likely no idea why u would want to record at a lower resolution tho.
in le title
So I would assume 720p60fps works
I've got more to gain from 60fps than 1080p.
Yeah but you can use both at the same time read the Amazon title......
in le title
Oh, okay then.
Read the description, and it says "Note: Video input supports up to 1920 * 1080 at 60 fps (Hz), while maximum recording quality is 1080p at 30fps."
The official website also lists the recorded gameplay will be 1080p at 30fps. For 60 fps, 720p is the highest resolution. http://www.avermedia-usa.com/avertv/product/ProductDetail.aspx?Id=503&tab=UserManual
yay i wasnt wrong
It says that it can input 1080p60, but can only record 1080p30.
I trip to make the fall shorter
