First time building, does it look alright?
Go to solution Solved by MunnyMang,
i'll probably go for this as it's the cheapest build yet and still gives me an ssd to play with.
even if i don't i think i have a better idea of what i should do now, thanks a lot you guys were a big help.
so i bought a pre-owned gaming rig a couple years back which first got me into the whole PC gaming/building world. next month im moving down to university and because i don't want to be lugging this huge full tower PC back and forth i decided on a mini-itx build, i'm a little nervous because this'll be my first time actually putting together an entire PC from scratch.
tell me if it looks to be good or if i am bottlenecking somewhere, or if i could opt for some cheaper parts and get the same performance.
i'm gonna need a decent amount of power because im going for an architecture course and i've been told there'll be a fair amount of digital modelling, designing and rendering.(as well as the fact that i want to be able to play games)
http://uk.pcpartpicker.com/p/T2TKmG
https://linustechtips.com/topic/434105-first-time-building-does-it-look-alright/
Get a cheaper cooler and even a processor to get a 980ti. It should do better in games that way, most games don't make use of the i7 very well.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
get an sdd please a samsung 850 evo or crucial mx or bx would be great i preffer the samsung ones
and maybe get a skylake (i5 and then get a 980ti) cpu and mobo
are you really gonna oc otherwise this cooler is overkill
and get a psu from evga a 650 watt would be plenty
CPU: 4790K (4.8 ghz) | COOLING: Custom Liquid Cooling (240 mm rad) | GPU: GTX 980 ti Superclocked+ (2x)  | MOBO: Gryphon Z97 Armor Edition | RAM: Kingston (4x4 gb 1600 mhz) | SSD: 850 Evo (250 gb) | HDD: Black (1.5 tb) | CASE: Enthoo Evolv | PSU: G2 850 (850 w) | DISPLAYS: Acer XB270HU bprz / Philips 246V5LHAB/27 (3x) | KEYBOARD: Vengeance K60 | MOUSE: Naos 7000 | HEADSEAT: H Wireless / Cloud 2 | For the exact parts visit my PCPartpicker it even includes my Desk and some other stuff.
Looks good, though I would try and aim for an SSD and a better monitor, IMO 1080p 60hz is a waste of a 980
If he gets Skylake then he's gonna have to pay a shit ton for DDR4.
ddr4 isnt to bad ram price have gone down so much
But still pricier than DDR3.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
Bam?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£239.94 @ Aria PC)
CPU Cooler: Corsair H80i GT 70.7 CFM Liquid CPU Cooler  (£77.08 @ Amazon UK)
Motherboard: MSI Z97I Gaming AC Mini ITX LGA1150 Motherboard  (£107.68 @ Amazon UK)
Video Card: Asus GeForce GTX 980 Ti 6GB Video Card  (£538.02 @ CCL Computers)
Case: Corsair 250D Mini ITX Tower Case  (£72.08 @ More Computers)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  (£84.78 @ Scan.co.uk)
Monitor: AOC G2460PQU 144Hz 24.0" Monitor  (£197.69 @ Aria PC)
Total: £1416.14
Generated by PCPartPicker 2015-08-20 17:19 BST+0100
Bam?
Total: £1416.14
Needs SSD then it will be spot on.
wow thanks guys a lot of really quick responses, i figured i was going to have to wait awhile before things picked up.
so what i'm hearing is, my cpu cooler is overkill, i should just upgrade to 980 ti if i'm around that price range anyways and grab an ssd?
Bam?
Total: £1416.14
this looks really good, it's a little pricier and since i haven't moved in yet i'm trying not to go too far beyond £1000. but i'll definitely take this build into consideration.
This is what I would do:
  • 120GB SSD for your operating system.
  • R9 390X, because it's a lot cheaper for almost the same performance.
  • Nepton 240M instead of the H100i. It's much quieter and performance is also better. And it's also cheaper. But it's a bit hard to mount. I experienced myself. But shouldn't be too much of a problem.
  • EVGA PSU. It's a lot cheaper but also fully modular and 80+ gold rated. EVGA's customer support is outstanding. So definitly a good choice to go.
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler  (£76.98 @ Novatech)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive  (£40.06 @ Amazon UK)
Storage: Toshiba  500GB 3.5" 7200RPM Internal Hard Drive  (Purchased For £0.00)
Storage: Toshiba  3TB 3.5" 7200RPM Internal Hard Drive  (£64.94 @ Amazon UK)
Video Card: MSI Radeon R9 390X 8GB Video Card  (£329.99 @ Ebuyer)
Case: Corsair 250D Mini ITX Tower Case  (£73.42 @ Amazon UK)
Monitor: Dell P2214H 60Hz 21.5" Monitor  (£137.06 @ Scan.co.uk)
Total: £1192.31
Generated by PCPartPicker 2015-08-20 17:23 BST+0100
It's already over his budget.
Then cut down on something else, no build at this price should be left without an SSD...
There's nothing else I could cut down on that would make sense.
Just go with the monitor he selected and simply not a 980Ti? Not everyone needs a 980Ti just because it has a pretty good value.
A 970, R9 390, R9 390X is totally fine.
Especially because he could crossfire 390Xs and get even better performance than a 980Ti. Especially with that Crossfire scaling which works better than SLI.
And the price difference wouln't even be that high. Price/performance wise it's pretty much the same.
You paired a 980Ti with a 1080p monitor, what do you mean "theres nothing you could cut down"
