750ti stuck at 405mhz
Solved by Bananasplit_00,
This is under Kombustor. It only hits 405. The boost cap is 405 as well.
my card had/has this problem, take out the card, re-place the card and then reinstall the driver, worked for me sortof, my 750TI is the MSI OC GTX 750TI so if you have the same one the card is probably to blame, 405Mhz is the lowest clock the card defults to and this hapaned to me when trying to overclock my card also my card has some sort of power problem i think
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting0 -
2
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
Shane Martin ·
Posted in Displays2
