I need help finding a flash drive that fulfills a specific set of requirements. It's going to be used with a Windows tablet. Note that it will be used in a USB 2.0 port, but it's likely that what I need will be found in a USB 3.0 drive. What do I need?
  • 32GB or 64GB capacity (64GB preferred.)
  • Sustained 40MB/s read and write (not by specification lists alone but by real world testing), will settle for 40MB/s read and 25MB/s write sustained.
  • Slim form factor preferred
  • No overheating issues (it can be an issue with smaller drives.)
  • Would prefer known brands such as SanDisk, Corsair, Kingston, Patriot, etc.
  • Available at Target, Best Buy or Amazon
  • Under $30
I've been looking around but I'm not entirely sure about what's good and what isn't, so it would be great if someone could help me out. Thanks in advance.
https://linustechtips.com/topic/424194-need-help-finding-a-flash-drive/
  • Under $30
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007960%204814%204025&IsNodeId=1&bop=And&Pagesize=90&Page=1
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
Funny.
I'll have to look at reviews for both of them. Thanks for actually providing useful posts.
Unlike that guy, aint nobody got time for that kawaii stuff.
Flash drives are like ram these days. As long as you get a good brand they're basically all the same. The problem is the interface, USB 2.0 only supports up to 60mb/s in theory where's in the real world you're more likely to get 30mb/s. max
-アパゾ
I was just running some benchmarks with my external HDD and I was able to go around 40MB/s if not above, so I think the ceiling should be fine. Same, my MicroSD card will do 22MB read and 10MB write in a USB 2.0 adapter. I may very well be wrong, but the speed ceiling should be fine.
I forgot to mention that your transfer speed will depend on what is being moved over the bus and how the controller in the drive handles different types of data. An ssd has the same problem but its alot more noticable on flash drives.
-アパゾ
i bought a 128gb usb stick off of ebay for dirt cheap, was like £5 so only like $8
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
Have you filled it yet? No name brand and flash drives that can be cheaply knocked off have a common issue where unscrupulous suppliers fake the size of the devices and use lower capacity memory. so as soon as you go over the real amount all of the data ends up corrupted.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
no i haven't, only really use it for a few films and to install an os.
I'll have to look at reviews for both of them assuming there will be reviews for them. Thanks for actually providing useful posts.
Both have 4.5/5 star ratings. Gotta love SanDisk :) I've never had one of my SanDisk flash drives fail
Funny.
the trouble with 3.0 is you can't use it as a boot drive. i think so. correct me if i am wrong.
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
I've been able to boot off of USB 3.0 drives in USB 3.0 ports and USB 2.0 ports fine. Either way, it probably wouldn't be used for booting into OSes anyways.
