Moderate overclocking. Cooling options
You are better getting the nh-d15 than the h50 but yes it will be enough
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
An air cooler would be sufficient for your needs.
9800X3D / Gigabyte X870E Aorus Elite / 32GB 6000mhz / EVGA RTX 3090ti FTW3 Ultra / AW3425DW / Logitech G502 / Logitech G915 / Sennheiser HD 600
M3 Max 16" MBP 48GB / iPhone 17 Pro Max
Depends on how lucky you are... silicon lotery. If you chip is good then yes.
H60 is prety bad cooler IMO rather get be quiet! Shadow Rock 2. It is cheaper, it is more silent, it performs a lot better. Just make sure if it can fit your case.
NH-D15 is amazing i have my 4790k at 4.94ghz on it
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
I know, is huge, but is a little better than h100i so it's something
Stay away from 120mm AIO's unless you have an ultra small case and don't have enough room for a half decent air cooler.
For roughly the same price you could get a Phanteks PH-TC14PE which would be more than adequate, and actually perform better than the H60.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
thats not a moderate OC. the stock of that chip is 3.5Ghz. your gonna be pushing it 1+Ghz above what it normally runs at. mine is at 4.8Ghz on a H110i and seems pretty happy with it. id go with the H110i seeing as if youve never OCd before when you see the speeds you get from it your gonna want to go faster! the H110i is way overkill but it will let you have more room in the future to OC then getting one that "just does the job now"
Oh yeah. I almost couldnt fit my 980ti in the top slot on my Z97 FTW
i had 4.3 on the stock cooler with my 4670k so...
That was my old rig now i have a 4790k^
Voltage?
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
Voltage?
1.28-1.3
I've had both the nh-u14s and the h100i. The noctua was quieter but the corsair has lower temps. However I have a 5820k which puts out significantly more heat than a lga 1150 chip. So for me the noctua was just barely not enough (spikes into 85C+ under full load). With lga 1150 noctua or be quiet or any large air cooler would be adequate.
I've had both the nh-u14s and the h100i. The noctua was quieter but the corsair has lower temps. However I have a 5820k which puts out significantly more heat than a lga 1150 chip. So for me the noctua was just barely not enough (spikes into 85C). With lga 1150 noctua or be quiet or any large air cooler would be adequate.
What you have there is not the nh-d15 so don't compare them
At 1.2v a hyper 212 evo will do 4.5ghz at around 20°c ambient, anything over 1.2v is too much for it. The h60 or any 120mm liquid cooler isn't worth the cost unless you can't fit anything bigger and can't get a decent air cooler. If you want liquid cooling, I'd recommend looking at dual 120mm (240mm) kits, or at the very least a thick 140mm kit
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
alright so a hyper 212 would be fine for my needs?
well maybe if you looked online you'd see the performance of the u14s and the d15 is almost identical. The problem with all air coolers is they get bottle necked by the heat pipes ability to transfer heat. In other words when under full load the fins aren't very hot to the touch as the high temp is localized at the bottom of the heat sink.
water cooling solves this problem because it transfers the heat away much faster from the heat spreader.
I might be wrong i don't deny that but what i could find is that the u14s in full load will hit 63 and nhd15 will hit 57.Again...what you say is true so perhaps for a cpu that outputs more heat a water cooling system will be better.Not sure about the bottleneck but sounds logical.
mine, 1.277, 4.1Ghz... *starts crying hard*
Ouch :(
