Going from GTX 760 to GTX 970
Kevguy
My current gaming machine has an ASUS GeForce GTX 760.  I just purchased on sale from NewEgg the ASUS GeForce GTX 970 STRIX.
I was talking to my buddies last night and they told me I won't notice any difference unless I overclock my CPU and the GPU.  Anybody know if this is true or not?  I hope not as I just purchased a Dell H2415 display to go with the card.  I am currently not overclocking anything as I don't really know how too.
Intel i7-4790K Processor, 32 GB Kingston HyperX Fury DDR3-1600 RAM, ASUS Z-87 Pro Motherboard, Corsair RM 750 PSU, 250 GB Samsung 840 EVO SSD, 2 x 1TB Seagate Barracuda HDDs, ASUS GeForce GTX 970 STRIX GPU, Corsair Carbide 500R Case, AFT Pro-77U Card Reader, Dell UltraSharp 24 Monitor – U2415, Logitech HD Pro Webcam C920, Windows 9 (Windows 10 with StartIsBack++)
What cpu do you have? And you will notice a difference. I went from a 660 to my current 970 and there was a huge difference.
Don't forget to Like the things you like!
What's the rest of your system?
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
You will notice a difference definitely.
Your friends are stupid
It will be an insane difference, a 760 is no where near as powerful as a 970. If you have a old crappy cpu that is another story, but assuming the rest of your system is ok, the 970 will be a BIG increase.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
Sorry, I should of mentioned that.
Intel Core i7-4790K
32 GB of Kingston HyperX Fury DDR3-1600
ASUS Z87-Pro motherboard
1TB Seagate Barracuda Hard Disk
Corsair RM750W Power Supply
ASUS GeForce GTX 760 Video Card (970 STRIX will be replacing this one)
Dell H2415 Monitor (just arrived in the mail yesterday)
Intel Core i7-4790K
1TB Seagate Barracude Hard Disk
 i can take your 760 of your hands :D
Also dont forget to follow your own posts so you recieve notifications
Intel Core i7-4790K
32 GB of Kingston HyerX Fury DDR3-1600
Your friends either are stoopid or not sober.
You should notice a difference of min 20 fps on higher settings (without oc).
You can oc to get more power but, since your cpu is already really strong it won't need it to keep up with the 970.
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
I will be selling it.
You should notice a difference of min 20 fps boost on higher settings.
Currently getting 59-60 FPS playing War Thunder on high settings, but renderings a a little slow at times.
You will see huge difference without any overclocking, especially with that 4790 driving whatever card you throw at it.  Your friends are uniformed. Nice rig!
Intel Core i7-4790K
You'll probably see a fps increase of about 30% and higher without overclocks. That's a very significant increase.
an I7 4790k? no difference? WTF? The 760 is budget gaming card, the 970 is one step above that and FAR more powerful. The only thing that would be a limiting factor is the CPU, and since even a SB i7 would see a performance increase, thats BS.
that was not an option :D NOW HAND IT OVER AND NOBODY GETS HURT :D
I see your point.  But it's only at 760?
I have a 760 and could use it to sli, how much will you be asking for it?
Get 390 for the money you have PSU to support it its better then 970
Catman - a Wolverine wanna be
I dunno what to sell it for yet as it's still in the PC and the 970 won't arrive until early next week.
Are you in the UK?  I'm in Canada and I'm not sure if mailing it to you worth it?
#1.  You are changing the topic.
#2.  That's your opinion.
#3.  The purchase is already done.
Only at 1440p and above. If he's playing 1080p still then a 970 is great for that!
You'll like your 970 ! It's great for overclocking.
First build every: Intel Core i7 4790K, Asus Z97-A/USB 3.1 motherboard, Kingston HyperX FURY 1866 2x8 16GB Kit, Gigabyte Windforce GTX 970 G1 Gaming, Corsair Obsidian 450D Black ATX Mid Tower, Samsung 850 EVO 250GB & 3TB Toshiba HDD, EVGA SuperNOVA 750W G2, Corsair H100i GTX 240mm, Gigabyte Bluetooth 4.0/Wifi Card, Logitech G700S. Running on Windows 10
Surface Pro 3: i5 4300U with 8GB of ram and 256GB SSD. Running Windows 10 Pro
@1Scotty1 did the same upgrade.
You remember well, my friend :) It is true, I had a 760, then upgraded to a 970 and the upgrade was significant, even more so, when I got a second 970 for SLI :) up until recently I sold them and got a 980Ti for the money :)
Yeah. Still haven't painted the 980ti have you?
